Hi.
My request
{"ID":2,"Key":{"Name":"TRI.N","ServiceId":10002}}
I got this error
Request Rejected: Request key did not contain service Id.
Why?
Hi.
My request
I got this error
Why?
@Ilya Vasserdam Where did you get the parameter ServiceID. Its not documented anywhere in the message description.
Try omitting this key/value pair and try again.
{"ID":2,"Key":{"Name":"TRI.N"}}
[{"ID":2,"Type":"Status","Key":{"Name":"TRI.N"},"State":{"Stream":"Closed","Data":"Suspect","Code":"AlreadyOpen","Text":"Request Rejected: Request key did not contain service Id."}}]
I got this parameter from RSSL protocol.
The websocket protocol is different from RSSL protocol. Can you confirm that you are referring to the new Elektron Websocket API, and not the old RIS/TRIS API.
Even with the new EWA, I see some old reference to the ServiceId, which seem to have been removed/replaced with Service now. Can you try your request using the key Service instead. Also, can you please confirm that you have the latest version of ADS running.
I added the serviceId only because of the error text. I did not see any mention of serviceid(or service) for websocket. {"ID":2,"Key":{"Name":"TRI.N","Service":"10002"}} . I got access 4 apr. I think he is the last. (WebSocket protocol, logon - OK)<br>I can clarify if necessary. ADS????
Sorry. Other error.
[{"ID":2,"Type":"Error","Text":"JSON Unexpected Value. Received 'hdEDD' for key 'Service'","Debug":{"File":"Converter/jsonToRwfSimple.C","Line":7434,"Offset":41,"Message":"{\"ID\":2,\"Key\":{\"Name\":\"TRI.N\",\"Service\":\"hdEDD\"}}"}}]
You will have to confirm from your market data administrator, if the Service "hdEDD" is configured for websocket access in your ADS server.
