RFA J 7.6.1.L1 - Missing data when using muilti-threading
We are having a problem with missing data when using multi-threading in our application. I'm hoping someone could give us an idea about what could be wrong.
Our application has a number of users so what we do is:
When we receive a subscription request from a user, we create a thread and:
- We create or reuse a previously created RFA session.
- We subscribe all the requested RICS with TREP using a single queue (we've also tried wrapping the queue in a queueGroup)
- we start calling the dispatch on the queue
We receive data for almost all the subscribed RICS, except for a couple, it doesn't matter how many RICs subscriptions we make, we always miss data from 1 or 2 RICS.
Again, this only happens if we use multi-threading, when we use a single thread to serve all requests, we receive all data.
I hope the explanation makes sense, thanks in advance for any help.
treprfarfa-api
11.3k 25 8 13
Hi @tdlc
Normally, application should receive response for each subscription via image or status message. I'm not sure whether your application has been implemented to process status message or not. The status message normally be received instead with reason in status text. It might provide some clues for this issue.
Could you provide more details on how your application utilize RFA for multi-threading?
