In Excel I am able to retrieve data from sources different to IDN using RtGet() formula as follow:
=RtGet(MY_SOURCE, MY_RIC, "Bid")
Is there a way to do the same in Python, e.g. using get_data() function?
Thanks in advance.
Thanks in advance.
Eikon Data APIs currently can only retrieve market data from Eikon platform, and not from your TREP middleware where you have those sources. When we introduce streaming capability into Eikon Data APIs, which is currently targeted for Beta in Q3, then you will be able to retrieve market data from your TREP provided the ADS your Eikon mounts to is version 3.2.4 or higher.
In the meantime you can retrieve market data from your TREP using legacy Eikon COM or Eikon .NET APIs, which work with any version of ADS. It is possible to use AdfinX Real-Time library of Eikon COM APIs in Python, albeit only in 32-bit one, similar to how AdfinX Analytics library is used in Python in this article.
Is it now possible to get data from an internal source via the Python API?If yes, could you provide an example?
@matthias.mayr
Old threads that already have an accepted answer are not monitored by forum moderators. To ask a new question always start a new thread.
Streaming data has been introduced into Eikon Data APIs, however at the moment it is limited to streaming data provided by Eikon platform. The capability to retrieve streaming data from local TREP (including internal sources) is expected later this year. In the meantime you can use Python implementation of Refinitiv Data Platform Libraries to retrieve streaming data from Deployed Platform aka TREP. Refinitiv Data Platform is the strategic platform that will provide data to both enterprise and end user applications. Refinitiv Data Platform Libraries will eventually replace Eikon Data APIs libraries when Refinitiv Data Platform has been sufficiently developed to provide all the capabilities currently available through Eikon APIs.
