Filter not matched results using API in WC1
I make the following request to create the simple case
"secondaryFields": [{
"typeId": "SFCT_5",
"value": "FRA"
"entityType": "INDIVIDUAL",
"customFields": [],
"groupId":"{ {group-id}}",
"providerTypes": [
"WATCHLIST"
"name": "emmanuel macron"
and have the following response
"resultId": "0a3687d0-69ca-1dac-9a7a-1e1d008224e3",
"referenceId": "e_tr_wci_1748082",
"matchStrength": "EXACT",
"matchedTerm": "Emmanuel MACRON",
"submittedTerm": "emmanuel macron",
"matchedNameType": "PRIMARY",
"secondaryFieldResults": [
"field": {
"typeId": "SFCT_5",
"value": "FRA",
"dateTimeValue": null
"typeId": "SFCT_5",
"submittedValue": "FRA",
"submittedDateTimeValue": null,
"matchedValue": "FRA",
"matchedDateTimeValue": null,
"fieldResult": "MATCHED"
"sources": [
"b_trwc_PEP N"
"categories": [
"PEP"
"creationDate": "2019-04-04T13:10:02.938Z",
"modificationDate": "2019-04-04T13:10:02.938Z",
"resolution": null,
"resultReview": {
"reviewRequired": false,
"reviewRequiredDate": "2017-06-15T00:00:00.000Z",
"reviewRemark": null,
"reviewDate": null
"resultId": "0a3687d0-69ca-1dac-9a7a-1e1d008224e7",
"referenceId": "e_tr_wci_1824072",
"matchStrength": "WEAK",
"matchedTerm": "NWORA,Emmanuel M",
"matchedNameType": "AKA",
"field": {
"typeId": "SFCT_5",
"value": "USA",
"typeId": "SFCT_5",
"matchedValue": "USA",
"fieldResult": "NOT_MATCHED"
"sources": [
"b_trwc_419",
"b_trwc_362",
"b_trwc_368",
"b_trwc_457"
"categories": [
"Law Enforcement",
"Law Enforcement",
"Regulatory Enforcement",
"Law Enforcement"
"resolution": {
"statusId": "0a3687d0-693a-1414-9a65-a01700000cdf",
"riskId": null,
"reasonId": null,
"resolutionRemark": null,
"resolutionDate": null
"resultReview": {
"reviewRequiredDate": "2015-10-01T00:00:00.000Z",
"reviewDate": null
If I understand correctly it's not possible to say to API to filter only matched entities? Am I right?
Thank you.
world-checkworld-check-one
2.4k 5 5 5
@pavel.ustinov
You can choose to remove the false matches from your result by editing the auto-resolution settings of your account to remove the false matches from screening results, this setting would be reflected on your API as well, you can edit the auto resolution setting from your World-Check One UI->admin->edit auto-resolution setting.
