How to get the RowCount as Header part of the endofday extract using DSS Select
@ Christiaan Meihsl,
We are using DSS Select REST API to extract endofday data .Using below endpoint
https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/Extract.
Providing the REST body as :
"ExtractionRequest": {
"@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.ElektronTimeseriesExtractionRequest",
"ContentFieldNames": ${market_fields},
"IdentifierList": {
"@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.InstrumentListIdentifierList",
"InstrumentListId": ${market_instrument_list_id}
"Condition": {
"StartDate": "{startDate}",
"EndDate": "{endDate}"
Providing market_fields and market_instrument_list_id as list .
In a different thread I got to know its possible to get the total RowCount of extract as Header in the response itself, could you help me how shall I get that programmatically (Any parameters to add/update in above REST body ? ) I want to test this using POSTMAN. We have been using python application which we migrated to scala one.
Many Thanks
tick-history-rest-apipricing
13.7k 26 8 12
@prachand2,
I'm sorry to say that is not possible. The Header/Footer functionality that delivers the RowCount is not available for the 4 Tick History extractions (ElektronTimeseriesExtractionRequest is one of them), it is only available for templates defined for scheduled DSS extractions, as discussed in this separate thread.
As a side note, I recommend you do not use the Extract end point, and replace it with the ExtractWithNotes endpoint. The Extract end point is being deprecated, as explained here.
Thank You We will be updating the extract endpoint.
