WC1: Is it possible to provide a city name instead of a country code for place of birth in secondary field parameter?
When creating a case I would like to use the place of birth for matching a case. Is there an option to provide the name of a city as place of birth? I only found the field "place of birth" from type "COUNTRY" in secondary fields. Is there any other possibility to match more precisely for place of birth?
world-checkworld-check-one
4.2k 7 5 6
@fhuth
Currently you can use only ISO country codes in the SFCT_4 field (Place of Birth) while sending your screening request for an individual.
You can find the supported country codes using the API call "SEQ-pre-country-list: Get the ISO country list"
