WC1: Entity fields
In the WC1 Entity object, I have a few questions regarding the different fields:
  1. Active vs Is Operational: what is the meaning of the "active" field? For the Vessel type, is it correlated in any way with the Is Operational present in the details list?
  2. In the Associate object (from the "associates" list), what does "reversed" stand for?
  3. what is "comments" for?
  4. "contacts" - are these possible for a Vessel entity?
  5. what is "deletionDate"?
  6. what is "description"
  7. files: what can we see here? Are there any files that can appear for a Vessel?
  8. images: are there any images for vessels?
  9. what is "updateCategory"? Is it relevant for Vessels?
Thank you!
world-checkworld-check-oneentity
4.5k 4 7 8
@cedric.lasbleiz
Apologies for the delay in response.
Please find the details below -
Active :Indicates the entity is active. (Vessel only)
Is Operational :This field would be populated if the entity is not operational
reversed :For Internal use only. To be ignored by the customers.
comments :N/A
contacts :N/A
deletionDate :Indicates when the WC profile was deleted
description :N/A
files :N/A
images :N/A.
Side note : Under the weblinks attribute in the JSON response, PHOTO indicates the page represented by the uri contains images.
updateCategory :For the category of update on the profile. Please find more information on the category here - https://world-check-one-pilot.accelus.com/1.446.2//js/fsp/help/assets/update-categorization-aug-2018.pdf
Hope this helps.
4.5k 4 7 8
@cedric.lasbleiz,
Thank you for your query.
Please allow us some time to get back with the requested information.
Hello @Prabhjyot.Mandla,
Any news regarding our answer?
Thank you
Apologies for the delay in response. We will get back to you as soon we have more details on the query.
Thank you for your patience.
@Prabhjyot.Mandla, any news on this query ?
