Multiple Stream Ids
Can multiple stream Id requesting the same data be encoded as 1 message and sent to ADH to handle fanout ?
elektronelektron-sdktreprrteta-apielektron-transport-api
@vishal.anand
Do you mean requesting the same item with different stream IDs to ADS with ETA (UPA)?
If you request the same item with different stream IDs to ADS with ETA (UPA), you will get the following error message.
Received Item StatusMsg for stream 6
        State: Closed/Suspect/Already open - text: "Item was reopened under new stream."
However, you can use RFA, ETA (ValueAdded with WatchList enabled) or EMA to request the same item because those APIs are able to handle fanout on behalf of the application.
For example, if someone requests for data for GOOGLE via ISIN as well as CUSIP the request from ADH will have different stream IDs but the data will be the same since they will both point to GOOGLE. My question is that is there any way in UPA to fanout the different stream IDs and not to process the same data multiple times for each stream ID? Or is there any way in UPA where I can insert multiple stream IDs in the same message or copy the RsslBuffers only at the end with different stream IDs?
Any update?
Hello @vishal.anand,
Please be informed that past questions with accepted answers are not actively monitored by forum's moderators.
Therefore, it's better to ask the new question and to include the link to the relevant info within the past question in it.
To clarify, UPA can not request data via CUSIP or ISIN. It can only be done via RIC. So both requests will establish streams via RIC.
Both EMA and UPA ValueAdd will properly handle the semantics of multiple streams for the same item on behalf of the application.
