issues with installing Elektron-SDK-1.3.0.L1.linux
I am trying to install Elektron-SDK-1.3.0 on my machine running centos 7.6.
But after downloading the zip file, Elektron-SDK-1.3.0.L1.linux_0.zip, and running the command "cmake3 -HElektron-SDK-1.3.0.L1.linux.rrg -Bbuild-esdk", I got the error messages below.
What have I missed? Please help!
Ken Wu
PS. I also attach the CMakeOutput.log(cmakeoutputlog.txt) for your reference.
elektronrefinitiv-realtimeelektron-sdksetup
cmakeoutputlog.txt (38.8 KiB)
7.6k 15 6 9
@wu_tzuchiang
First of all please make sure that the ESDK1.3 package you download is not corrupt.
-Can you build the previous version of the ESDK on the Linux machine previously?
-What version of Cmake you are using?
I just tested the issue by setting up a new CentOS7.6 and then install the latest version of CMake 3.14 with gcc-c++ 4.8 and then upload ESDK1.3.0 package to the Linux machine. I can run your command to generate make file and I can build it without the issue.
I notice that your output contains an incorrect path and it's "LIN3_64_GCC485". I suspect that there might be some issue which causes invalid linux name "LIN3" in CMake script.
As far as I remember I have to install redhat-lsb-core on CentOS, otherwise it fails to generate make file because some CMake seems to generate an incorrect value path.
-Have you installed redhat-lsb-core on the CentOS? if not please try
sudo yum install redhat-lsb-core
Then please run ./LinuxSoLink under ESDK1.3 root directory and ESDK1.3/Elektron-SDK-BinaryPack/ and try your command again?
moragodkrit,
after I installed redhat-lsb-core and ran the scripts you mentioned, everything worked like a charm. Thank you.
Ken Wu
I am trying to build the same package on Fedora 28. It always fails to build, although redhat-lsb-core is installed.
"make[2]: *** No rule to make target 'Elektron-SDK-BinaryPack_dacs_LIBRARY-NOTFOUND', needed by '/home/ayan/tmp/Elektron-SDK-1.3.0.L1.linux/setup/Elektron-SDK-1.3.0.L1.linux.rrg/Cpp-C/Eta/Executables/FED28_64_GCC831/Optimized/authlock'. Stop. make[1]: *** [CMakeFiles/Makefile2:3070: Cpp-C/Eta/Applications/Examples/AuthLock/CMakeFiles/authlock.dir/all] Error 2 make: *** [Makefile:84: all] Error 2"
By the way, I am using gcc 8.3.1. Anyone have a luck to build ETA/EMA successfully by following the instructions?
