Authorization Token Necessary?
I noticed that if I don't add an Authorization Token to the header of a Request but instead use Basic Auth with my username and password I'm still able to retrieve data. Is this approach ok?
dss-rest-apidatascope-selectdssauthentication
13.7k 26 8 12
@vikas.khurana, technically it works, but using that approach means you are going through the authentication process with each request. I'm not sure about this, but I think this might incur a slight overhead. I'd use the standard approach of tokens, which are valid for 24 hours.
@vikas.khurana yes, that should also work. it is working for me with postman. But the user has to enable "authorization" in the Headers tab
