Eikon Data AP via Python, getting a connection error. When connecting using ek.set_app_key('e8--------0'), Error on checking port 9000 :
Sorry I was running off Eikon Web app. I have since downloaded and installed locally and it fixed the problem. Thanks
4.6k 26 7 22
  1. Check that Eikon is running on the same machine where you initialize the api;
  2. If it is, go to ```C:\Users\YOUR_USER_NAME\AppData\Roaming\Thomson Reuters\Eikon API Proxy```, and check the contents of the .portInUse file, what does it say?
Thanks Zhenya,
I am unable to find the Thomson Reuters directory within my C:\Users\Admin\AppData\Roaming. I do have the Eikon web application loaded and connected. Any help is appreciated.
