Submit of CloseMsg failed
I am trying to request 12k of ric spread into 7 batches locally and encountered this problem on 1 out 3 computers.Apparently, the other two computers never encounter this problem. What does this error means? what is the root cause and how can i fix it?
//message from the local provider
2019-03-26 15:48:03.083 ERROR 24060 --- [ool-12-thread-1] c.t.e.a.OmmConsumerImpl                  : loggerMsg
    ClientName: Consumer_3_4
    Severity: Error
    Text:    Call to rsslReactorDispatchLoop() failed. Internal sysError='0' Error text='Submit of CloseMsg failed: <INIT_NOT_INITIALIZED>'
i run the provider using this command if it helps :
gradlew.bat runETAPerfProvider -PcommandLineArgs="-tickRate 20"
elektronrefinitiv-realtimeelektron-sdkjava
@muhammadismoktar
The error INIT_NOT_INITIALIZED indicates that transport has not been initialized. Therefore, it is unable to send a close message.
You may need to verify if there is a disconnection between that consumer and provider.
Normally Developer Community Forum is for how-to/general questions but your question seems to be more complex and requires investigation e.g. review source code, configuration, try to reproduce the problem etc.
I recommend you contact RDC subscribers in your company to raise a query through the premium support service. RDC subscribers should see a link "Contact Premium Support" when they are logged into the developer portal (https://developers.refinitiv.com/elektron/elektron-sdk-java).
For any difficulties submitting the query to us, please contact rdc.administrator@refinitiv.com.
