can i connect eikon data api from other pc?
i installed eikon in my server and i want to connect from other computer, can i do that?
I don't think so. The Eikon API Proxy used by Eikon Data API listens to TCP port on the localhost (127.0.0.1). The default port is 9000.
  TCP    127.0.0.1:9000         0.0.0.0:0              LISTENING
This is why you can only use Eikon Data API on the local machine.
