AdxRtList Source Down. What to do?
There is my question related to this one : https://community.developers.refinitiv.com/questions/33947/adxrtlist-what-rt-item-stale-means.html
So, I request for an image for a list of the tickers. There is a callback function that parses a response. To avoid Stale items, I've added source status check GetSourceStatus() to the callback function before any parsing done.
Here is what happened today:
I ran 5 requests one after another. 4 worked fine. 5th got me RT_SOURCE_DOWN.
So I discarded the data and re-ran it again 4 times with the same problem. Then I destroyed the Rtx object and created new one. That new one gave me the same behavior - RT_SOURCE_DOWN for all next requests. (note: I delete the object but do not release it. If I release it, I cannot create new . There was another ticket on the forum)
At this point I don't know how to recovery from this state. The only thing that always help - restart Eikon and application.
eikoneikon-com-api
@igorg when this happens, do you still see the streaming updates for any of the requested RICs inside the Quote app on Eikon?
@Zhenya Kovalyov, I didn't check the Quote. I just restarted the Eikon and it started to work.
This is not a good solution anymore, since the data collection is 1 step of the several steps process.. If it fails, all process fails. So I need to find out what to do in this case. Just sit and wait for a connection? Is there a way to re-connect?
@igorg the issue that you are describing does not fall under common problems for this API, we might need to escalate this. There are multiple reasons for RT_SOURCE_DOWN, but your app should successfully recover from all of them. Also, I can not really think of an issue with the real-time source that can be fixed by restarting Eikon.
I will wait for Alex's comment, but post instructions on how to collect logs for a case like this.
4.6k 26 7 22
@igorg
a. Close Eikon completely
b. You will need to configure the logs, if have not already. Go to Start > Thomson Reuters > Configuration Manager app and open the Logs tab.
Thomson Reuters Desktop - level 4
PIXL - all messages
RFA - activate RFA logs
AdminX-RT - All
c. Remove all logs from %PROGRAMDATA%\Thomson Reuters\Eikon Data\Logs\
d. Start Eikon and try to reproduce the error;
Once this is done, contact myself or Alex by email, we will get someone to look into this.
I will do. Thank you
But since it happened 2nd or 3rd time during last 5 months.. we will wait for a long time.
ok, just be aware that excessive logging will slow down Eikon a lot.
