Directory to RHistoryAPI
I would like to use RHistoryAPI and I could not find the directory E:\PLINK\TRUNK\... to add the reference. I used the reference to C:\Program Files (x86)\Thomson Reuters\Eikon\X\Bin\RHistoryAPI.dll but It does not work.
Thank you for your help
eikoneikon-com-api
What symptoms did you experience after establishing the reference to "C:\Program Files (x86)\Thomson Reuters\Eikon\X\Bin\RHistoryAPI.dll"? I just downloaded the example from RHistory tutorial, changed RHistoryAPI.dll VBA reference to point to "C:\Program Files (x86)\Thomson Reuters\Eikon\X\Bin\RHistoryAPI.dll", and was able to retrieve the data by clicking the buttons in the example. What do you see when you follow the same procedure?
Thank you for your reply.
