Eikon API Chain subscription - RIC Position Changed Query
I am using the Eikon API .NET version to subscribe to a chain RIC.
I had a query relating to the UpdateType.Changed update type.
1. Under what conditions does the callback OnDataUpdated fire for this case?
2. What does it mean when a subscribed RICs position has changed? Is that just to indicate where on the code page it will appear?
4.6k 26 7 22
@emir.subasic
1. It is going to be fired if the position on the ric has changed, example of that is EURBEST= that is dynamically sorted;
2. If you are only tracking the actual fields on the RIC, tracking the changed event does not bring any added value
Thanks for confirming.
Please close.
