ATS Open Webservices XMLConsoleApp connection issues
I'm using XMLConsoleApp.jar on server A (my config server) to create records on server B (my TREP server).
The details for server B is defined in ServerConfig.xml.
I can successfully ping server B from server A, and I can successfully log in to ATS GUI with username and password as defined in ServerConfig.xml.
But I have login issues when running XMLConsoleApp.jar on server A towards server B, below error message is thrown:
--> Login Failed <--
--->Cannot connect to server. Data dictionary is locked.
I hope I'm at the right forum, any help appreciated.
Thanks,
Johan
elektronrefinitiv-realtimetrepinfrastructureATSxml
11.5k 16 7 10
Hello @johan.lundquist
The ATS WebService is a part of ATS server. I recommend you raise the ATS support ticket via My.Refinitiv Support - so the ATS support team can verify this ATS server issue.
