Where to put OMM Viewer.xml and What is the format
Hi
We're using ReplayService and try to use OMM Viewer Client which placed under `{installDir}\Replay Trep\tools\start_ommviewer.cmd`
But It seems service name can be specified only through ommviewer.xml that I can find nowhere.
Please share some example of ommviewer.xml file, and tell where to place it.
Regards
Jin
treprfarfa-apiOMMreplay-tool
@cho.seungjin
OMMViewer uses the configuration file from \tools\rfa\ommconfig.xml. You need to configure the IP address or hostname in the serverList configuration of localConsumerConnection. The value should be localhost or 127.0.0.1 for the replay service.
After running the application, please specify the username in the dialog box
If the application is able to connect to the replay service, the list of available services will appear in the list box. There is no configuration for the service name.
If the list of service is blank, please verify the application log on the console.
