Is there any special configuration to enable IS_EXEMPT
As a part of invoice in body the following xml node has been added in the request, have done this so that tax is not applied or calculated for particular order amount
<ns:IS_EXEMPT>true</ns:IS_EXEMPT>
<ns:EXEMPT_REASON>99</ns:EXEMPT_REASON>
In the response I could see , the the tax calculated and following
<MESSAGE> <LOCATION>TaxFinder.determineApplicableTaxes</LOCATION> <CATEGORY>CALCULATION</CATEGORY> <CODE>EXEMPTION_CERTIFICATE_PROCESSING_DISABLED</CODE> <MESSAGE_TEXT>Exemption Certificate processing has been disabled.</MESSAGE_TEXT> <SEVERITY>0</SEVERITY> </MESSAGE>
Is there anything else that need to be done to exempt tax for a order beside adding the isExempt and exemptReason node in the SOAP request
Regards
Roshan
indirect-tax-api
Hello @roshan.shrestha!
This sounds like a question for our Support team. Please log a ticket with this information on our Customer Center: https://tax.thomsonreuters.com/site/support/onesource/indirect-tax/. Thank you!
