what is the RIC code for FX CADUSD when usd is on the right?
elektronrefinitiv-realtimeelektron-sdkrics
@georgezgj Those are not valid RIC's. Please use RIC search tool and key in your instrument (AUD for example) and select FX and Money category, to identify the appropriate RIC of interest to you.
Try CADUSD=X. It is a calculated cross rate.
In addition to CADUSD=X (which is a ten minute snapshot), you can also use CADUSD=R for a realtime Refinitiv calculated cross. The reason we have a calculated cross is the convention is USDCAD (which is CAD=) and very few people contributing for the other way around.
Both CADUSD=X and CADUSD=R didn't work, We use Elektron API to register the instruments to get rate update. Some currencies require the invert Rate( USD on the right), such as CAD, EUR,AUD and etc. What i need to know what instrument codes to register to get the invert rate.
@Tim Smith
Hi @georgezgj those are the correct codes. The market convention for the Canadian Dollar to based on 1 USD (which is of course different to most other global currencies) eg USD to CAD and the code for that is CAD= The coee for the Inverse is CADUSD=R - this is calculated as very few people provide us with a quote in the market. If those codes didnt work then there must be an issue, what error message did you get when you tried to call them in?
What is the status message when you subscribe to those instruments. What API and language is being used. Does the user have correct entitlements? Here is the sample response when using EMA:
Item Name: CADUSD=R
Service Name: ELEKTRON_AD
Item State: Open / Ok / None / 'All is well'
PROD_PERM(1): 5320
RDNDISPLAY(2): 153
DSPLY_NAME(3): ThomRtrs
TIMACT(5): 12:56:00:000:000:000
NETCHNG_1(11): -0.0018
HIGH_1(12): 0.7584
LOW_1(13): 0.7562
CURRENCY(15): 840
ACTIV_DATE(17): 26 FEB 2019
OPEN_PRC(19): 0.7579
HST_CLOSE(21): 0.758
BID(22): 0.7562
BID_1(23): 0.7564
BID_2(24): 0.7564
ASK(25): 0.7564
ASK_1(26): 0.7566
ASK_2(27): 0.7566
ACVOL_1(32): 61133.0
TRD_UNITS(53): 4
PCTCHNG(56): -0.24
OPEN_BID(57): 0.7579
OPEN_ASK(59): 0.7582
CLOSE_BID(60): 0.758
CLOSE_ASK(61): 0.7583
@Gurpreet
we tried both X and R, Here are what we got:
Item Name: AUDUSD=R Item State: Closed / Suspect / Not found / 'The record could not be found'
Item Name: AUDUSD=X Item State: Closed / Suspect / Not found / 'The record could not be found'
Item Name: AUDUSD9M=X Item State: Closed / Suspect / Not found / 'The record could not be found'
@Gurpreet We got:
Item Name: AUDUSD=R
Service Name: hEDD
Item Name: AUD=R
Service Name: hEDD
But following are ok:
Item Name: AUD1Y=R
Service Name: hEDD
Item Name: AUD3M=R
Service Name: hEDD
Thanks!
@Gurpreet., thank you, will take a look.
