How can I extend the IBarData in foreach (IBarData bar in chunk.Records.ToBarRecords()) to access other fields
I use NDA_RAW in my request and in the debugger I can see the records in the data chunk, but how can I access the individual keys in the dictionary?
            request = timeSeries.SetupDataRequest("ESc1")
                .WithView("NDA_RAW")
                .WithAllFields()
		.WithInterval(CommonInterval.Daily)
                .WithNumberOfPoints(10)
                .OnDataReceived(DataReceivedCallback)
                .CreateAndSend();
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonnda-raw
You cannot get IBarData from NDA_RAW view. Instead you need to iterate through the records in chunk.Records and for each record item use record.AllFields, which returns a dictionary of field names and values, e.g.
foreach (IData record in chunk.Records)
    foreach (string key in record.AllFields.Keys)
        Console.WriteLine(key + " : " + record.AllFields[key]);
Thanks Alex!
