How to get more details from WorldCheck response.
Hello Team,
We want to display WorldCheck Details on screen. In our Old API we had Description field in Category. But in current API I am not able to see this field in WorldCheck One API webservice response. Currently we are calling webservice to group and then we are calling Case screeningRequest webservice simultaneously. Can you please suggest on this?
world-checkworld-check-onescreening
4.5k 4 7 8
@pmahamunee,
Thank you for the query.
In order to get the description of a category, you will have to use the API call - 'Get a World-Check profile' for the specific World-Check profile.
When you use this API endpoint, you will get the information in below format -
"type": {  "category": {  "description": "The bodies detailed here, the Bureau of Industry and Security (BIS) and the World Bank, issue notices if they consider a person or company to be in breach of U.S. export regulations in the case of the BIS, or if they consider the person to have behaved improperly in the World Bank procurement process. Again, although there may be no reason why an action should stop you from dealing with a customer, this knowledge of the customer may be useful in assessing whether you wish to deal with them.",  "identifier": "ec_5",  "name": "Other Bodies",  "providerSourceTypes": []  },  "identifier": "t_trwc_5",  "name": "World-Check other bodies"  }
Hope this clarifies your concern.
