UpdateDate and EnteredDate in world check one pilot api are not exist
I use world check one pilot api make test,in screen result,for example ,{ {protocol}}{ {gateway-host}}{ {gateway-url}}cases/screeningRequest, but dot have "UpdateDate" and "EnterDate" in each result,however,there item are in World Check One WebSite,why?
world-checkworld-check-one
4.2k 7 5 6
@zhangdawei
The JSON response of the sync screening tries to provide only relevant information about a match which can let them decide if the match is a hit or not.
At this point we do not, provide the fields "updateDate" and "enteredDate" in the sync screening endpoint. The idea is to provide enough relevant information and not to clutter the JSON response with a lot of information.
You can use the endpoint "SEQ-case-investigate-world-check-profile: Get a World-Check profile" to get this information.
