Time&Sales(TAS) data retrieval via API
Hello Dev Team,
Is it possible to retrieve Time&Sales(TAS) data (equivalent of RHistroy in EIKON Excel) using Elektron API? If so, which service(s) to connect to from the API, and is CSV format supported?
Thank you.
elektronrefinitiv-realtimeelektron-sdkpricing
4.4k 10 6 9
Hi @NWM
I'm afraid Elektron Feed does not provide Time&Sales data. Which means you cannot get TAS via Elektron API.
You can get TAS data from Eikon, Tick History, and Knowledge Direct.
@Warat
Ok noted. Thank you for the response.
Regards
