RHistory - How can I query two table at once?
I want to retrieve the two different data table from the same instrument. After, I follow the step from COM APIs for use in Microsoft Office tutorial, I try to modify the code. However, I can get only one table at a time.
eikonapivba
I just find the solution on my own by naming the different query name. For example, m_RHistoryQuery1 and m_RHistoryQuery2. And then call it together.
@pongchai.paitoon, thank you for posting your solution :-)
