Response 401 UNAUTHORIZED using RestTemplate
Both sample Java code and Postman for /v1/groups work every time. However when using Spring and RestTemplate i get 401. Even stranger, the code worked occationaly while running it over and over, but I'm not able to reproduce it.
Request headers:
Authorization:
Signature keyId="f97121be-3d1d-493d-8029-5296d1070727",algorithm="hmac-sha256",headers="(request-target) host date",signature="7gxdTU6RcB8FAs1s31U0BNGXtRKgtm+3zjIzYcki8NM="
Mon, 04 Feb 2019 23:37:27 GMT
Response headers:
Authorization: WWW-Authenticate: Signature realm="World-Check One API",algorithm="hmac-sha256",headers="(request-target) host date content-type content-length
Date: Mon, 04 Feb 2019 23:37:43 GMT.
Code used is attached.
regards
Eirik
world-checkworld-check-oneerror-401
sample-code.txt (1.1 KiB)
Turns out that the I had to use the same date object for the hash and the header.
4.5k 4 7 8
@eirik.yksnoy,
Thank you for the query.
Can you please share the code where you are calculating the dataToSign value for generating the HMAC signature?
Hi @Prabhjyot.Mandla
I here is the code attached. It is basically copied from the sample code.
signdata.txt (1.6 KiB)
4.5k 4 7 8
@eirik.yksnoy,
Thank you for sharing the code.
I can see that in the generateAuthHeaderHash() you are passing only dataToSign as parameter/ argument. Can you please try passing the API Secret as well along with dataToSign as parameter? The change has to be made in 2 places.
i. Where you are defining the function
ii. Where you are calling the function
Hope this helps.
There was a problem with the url. It had the endpoint name doubled at the end.
Changing it from /v1/groups/v1/groups to /v1/groups resolved one issue.
Now however, the service seems unstable. Running the same code twice often results in one 200 and one 401. Is there a limitation on how often an endpoint can be called? I can't see a clear pattern. Attached is debug of the requests.request-response-log.txt
4.5k 4 7 8
@eirik.yksnoy,
You can hit the endpoint more than once at a time. If the request is being rejected due to overload, you would recevie Error 429 and not error 401. I would request you to please review the code if you are receiving Error 401.
From the request headers example, I can see that you are using the request headers as - Date, cache-control and Authorisation, which is failing.
Can you please let me know if you are receiving Error 401 for all the API requests with the above request header format?
