Using Eikon Data API (python) for the first time, able to setup eikon object with app_key but cannot get any data (Im getting '...Internal Server Error...'). Any recommendation?
This is the url it is trying to use is: http://localhost:8043/api/v1/data
Main part of the error message is:
Error code 500 | Server Error: Internal Server Error - <html> ...
File Not Found<br>Press "F5" to try to solve this issue, if the problem persists please contact your IT.
I'm following an example from the https://developers.refinitiv.com/en/api-catalog/eikon/eikon-data-api/quick-start section, using the following code:
import eikon as ek
ek.set_app_key("XXX")
result = ek.get_timeseries(["MSFT.O"],  start_date="2019-01-01", end_date="2019-01-31")
4.6k 26 7 22
@mhyll just checking, is your Eikon running?
