Using Local Exchange Timezone to query TRTH
I am doing Range query through C# api. I want to request data between two times expressed in the timezone of the exchange. Same as Datascope with this option :
Do you know how I can set this option ?
I know that C# has `DateRangeTimeZone` option but that doesn't allow me to have the local exchange timezone
dss-rest-apitick-history-rest-apitime-zone
13.7k 26 8 12
@webmastertux1,
In a nutshell, use this condition:
DateRangeTimeZone = "Local Exchange Time Zone",
Let me add a bit more detail:
I made an On Demand query for 1 hour Intraday summaries (bars), for RICs on Hong Kong, Germany and New York. The conditions included the following; I varied the value of DateRangeTimeZone based on what can be seen in the GUI:
Then I looked at the time stamps of the results:
MessageTimeStampIn = TickHistoryTimeOptions.GmtUtc,
DateRangeTimeZone = "UTC+01:00",
QueryStartDate = new DateTimeOffset(2016, 09, 29, 0, 0, 0, TimeSpan.FromHours(0)),
QueryEndDate = new DateTimeOffset(2016, 09, 30, 0, 0, 0, TimeSpan.FromHours(0)),
ReportDateRangeType = ReportDateRangeType.Range,
Test 1:
Result: timestamps range from 22:00 to 21:00, i.e. range is UTC+1
Test 2:
DateRangeTimeZone = "UTC+02:00"
Result: timestamps range from 21:00 to 20:00, i.e. range is UTC+2
Test 3:
DateRangeTimeZone = "Athens, Bucharest"
Test 4:
Not setting parameter DateRangeTimeZone
Result: timestamps range from 22:00 to 21:00, range is UTC+1 (i.e. the default is my own TimeZone).
Hi @Christiaan Meihsl,
Thanks a lot for your help. What happens in your test if you set "Local Exchange Time Zone" ? Personnaly, on my side I still have weird results.
For instance, I ask BAC.N (US stock) from 2011-08-11 00:00:00.000 to 2011-08-11 23:59:59.999 with the option `DateRangeTimeZone = "Local Exchange Time Zone"`
I should get only data on 2011-08-11 utc-4. but no I get that :
`BAC.N,Market Price,2011-08-10T16:00:00.178635000-04,Raw,UPDATE,UNSPECIFIED,,,,62,,24848,,10"`
Did I make a mistake somewhere ?
EDIT :
It looks like I don't have the same behavior between C# API and DataScope Select.
It works as expected in Datascope. Not in C#
I found. it was because I set QueryStartDate with a `DateTime` instead of `DateTimeOffset`, so somewhere a local machine time zone conversion was done in .Net
@webmastertux1, glad you found it !
