Using C# for TRKD Api, how can i batch request multiple rics?
Example:
Retrieving:
- fundamentals -> Get Ratios Report
- fundamentals -> Get General Information
What are the limit for a single batch if it is possible?
Thanks!
@2c5fe32b-b98f-460b-8e66-4a9be4cc983e
From the schemas, GetGeneralInformation_Request_1 and GetRatiosReports_Request_1 don't support batch request for multiple RICs.
<xs:schema targetNamespace="http://www.reuters.com/ns/2009/01/26/webservices/rkd/Fundamentals_1" xmlns:xs="http://www.w3.org/2001/XMLSchema"><xs:complexType name="GetGeneralInformation_Request_1"> <xs:attribute name="companyId" type="xs:string" use="required"/> <xs:attribute name="companyIdType" type="xs:string" use="required"/> <xs:attribute name="countryCode" type="xs:string"/> <xs:attribute name="lang" type="xs:string" default="en-US"/> <xs:attribute name="ShowReferenceInformation" type="xs:boolean" default="false"/> </xs:complexType>
<xs:schema targetNamespace="http://www.reuters.com/ns/2009/01/26/webservices/rkd/Fundamentals_1" xmlns:xs="http://www.w3.org/2001/XMLSchema"><xs:complexType name="GetFundamentalReportsPart_Request_1"> <xs:attribute name="companyId" type="xs:string" use="required"/> <xs:attribute name="companyIdType" type="xs:string" use="required"/> <xs:attribute name="countryCode" type="xs:string"/> <xs:attribute name="includeMedians" type="xs:boolean" default="false"/> </xs:complexType> <xs:element name="GetRatiosReports_Request_1" type="GetFundamentalReportsPart_Request_1"/> </xs:schema>
Each request supports one companyId.
