When we ask for Reuters market data, the following RFA logs will appear. They are empty. The following is a screenshot of the logs. How can we remove them?
treprfarfa-apilogging
@zhangping2
You can disable it by setting the value of logFileName configuration to none. The logFileName is a configuration in a connection.
If the application loads the RFA configurations from the Java Preferences, you can use the RFA configuration tool (config_editor) in the RFA package to add and modify its value.
