EIBOR Calculation API
I need API for EIBOR (Emirates Inter bank offered rate) calculation. I want daily EIBOR rates.
elektronrefinitiv-realtimeelektron-sdk.neteibor
Hi @0ff70b97-3f2e-40eb-bbeb-cc80f3a7a2fa
To consume the 'EIBOR=' RIC from our realtime Elektron feed, I would recommend you use one of our Elektron APIs.
Our realtime APIs are content-neutral - in the sense that they just deliver the data available on the feed - regardless of the content type - so there is not a dedicated API for EIBOR.
Depending on your choice of programming language, you can choose between Elektron SDK Java, Elektron SDK C++ and our Websocket API - details of each can be found at Elektron APIs
For all the above APIs, I would recommend you work through the relevant Quick Start section. After which you should proceed to the relevant Tutorials / examples / documentation.
