How can I use RFA to get Bond Info
as title, i can get the ticker info which it have FID ...
but i want get something else info in Bond view etc. Bond Rating Detail
I want make sure did RFA API support this feature?
thanks,
treprfarfa-apibonds
Hi @2e0e64ae-3687-4103-b0f4-c298341fab04
Our realtime APIs are designed for accessing realtime streaming tick data from our Elektron real time service and other realtime data sources.
The Bond View data (for example) is considered Reference data and requires access to a reference type content either via Eikon or Datascope. For this you would need to use an Eikon API or access the Datascope content via a Datascope REST API.
You may also wish to contact your Refinitiv Account manager to discuss the availability and possibility of accessing the required data via an Elektron Data Platform API which is currently in EAP.
