Best Swap Rates
In Bloomberg you can find the tickers sfsw2, sfsw3, sfsw4, ..., sfsw20
These CHF swap rates are based on a 6-month Libor. These are so-called Bloomberg Composite Rates (CMP). Bloomberg therefore selects the best bid and the best ask from a large number of interest rates.
Is there an alternative to these rates in Reuters? Thank you.
eikoneikon-com-apiforexswaps
4.6k 26 7 22
@6f337361-a81d-46d5-ba76-9a589504b834 the philosophy behind the contributed data is slightly different - we will display the last three quotes for all contributed instruments rather then the best quote. To see the get quote you can use the All Quotes app (type CHFAB6L1Y= ALLQ into the command bar and hit Enter). To view all tenors, type CHFAB6LIRS= Q into the command bar and hit Enter.
I suggest that you speak to your local Refinitiv support desk to confirm this with a content specialist.
@6f337361-a81d-46d5-ba76-9a589504b834 there are a few exceptions in the FX space though, for example EURBEST=or RUBBEST=, but CHF IRS are not covered in this way. Perhaps, if this is a critical requirement for you, you can request the creation of such a view.
