How to get the Analyst detail data of stock?
Hi:
I want to use the api to get analyst detail data for stock , for example like the excel to get
3.8k 4 4 6
Hi @andy.ej
It looks that your example is taken from the Excel templates library - "Analyst Detail.xlsx". This is a good start to see what data can be retrieved. Of course you can also use a Build Formula tool in Excel to find the data you are looking for and then that formula transform into an API request.
The example =TR() formula used in that specific Eikon Excel, cell C31 (removed cell referencing):
=TR("TRI.TO","TR.EPSEstValue.analystname;TR.EPSEstValue();TR.EPSEstValue.date;TR.EPSEstValue(OutputOptions=Prev).analystname;TR.EPSEstValue(OutputOptions=Prev);TR.EPSEstValue(OutputOptions=Prev).date","Period=FY1 Curn=CAD NULL='-' Sort:asc Rh:BrokerName")
can be converted to a python syntax
df, err = ek.get_data('TRI.TO', ['TR.EPSEstValue.brokername','TR.EPSEstValue.analystname','TR.EPSEstValue()','TR.EPSEstValue.date','TR.EPSEstValue(OutputOptions=Prev).analystname','TR.EPSEstValue(OutputOptions=Prev)','TR.EPSEstValue(OutputOptions=Prev).date'],{'Period':'FY1', 'Curn':'CAD','NULL':'-' })
df
Here is a good tutorial that will help you in understanding how to use python library data to access that data.
Thank you ,
How get the daily data ,like use parameter => 'Frq':'D'
@andy.ej same way you use any parameter, in the param dictionary. For example, from the code above:
{'Period':'FY1', 'Curn':'CAD','NULL':'-', 'Frq':D }
