Calais API returning timeout errors
We are getting errors when sending requests to the API.
Unable to execute request to Thompson-Reuters due to the following error: {"error": {"status": { "code": "500", "errorCode": "Request-Timeout", "errorDescription": "Timeout reached while processing the document." }}}
Documentation indicates that resubmitting the request may resolve the issue however, it's not. Is this a system wide issue?
apiintelligent-tagging-apierrorintelligent-taggingopen-calais-apisemantic-metadata-taggingtime-out
@b375f5ca-0258-4b29-b83c-65cc5ca961cb,
To investigate this issue we need the following information:
  • Are you getting this error for all documents or specific documents (if for specific ones please tell us the size of the doc and give us a doc example)
  • The URL you are using
  • Your user token
  • The headers you are sending
Hi @chris218, apologies if the question is still open. and if you are still getting the 500 error code, do let us know about it.
thanks
