WORLD CHECK ONE API TIME OUTS
Observing no response whatsoever within a 10 second timeout. Should it be set for a longer time out? We previously had a longer timeout (I forget whether it was 30 or 60 seconds) and reduced it to improve the student experience in the case of a timeout -- and we didn't see much difference in incidence rate of timeouts when we reduced the timeout, which suggests that timeout is just a symptom of failure, rather than being the root issue. Here is an example:
Here's debug output from me (successfully) retrying a request that previously timed out:
===== REQUEST =====
Request: POST http://rms-world-check-one-api.thomsonreuters.com:443/v1/cases/screeningRequest
Request headers:
content-type: application/json
authorization: Signature keyId="<redacted>",algorithm="hmac-sha256",headers="(request-target) host date content-type content-length",signature="I00IJdJSBSFfJbCuyilxsiCBJqhqgkxgIeLITI0vmrM="
date: Tue, 04 Dec 2018 18:54:00 GMT
connection: close
POST Data: {"groupId":"0a3687c3-6359-1ee7-98e3-243c0000073c","entityType":"INDIVIDUAL","providerTypes":["WATCHLIST"],"name":"Maya Lein","customFields":[{"typeId":"0a3687c6-64e5-1d18-9949-2253000010b5","value":"6556680064729088"}],"secondaryFields":[{"typeId":"SFCT_3","value":"DEU"}]}
===== RESPONSE =====
Code: 200
Headers
x-application-context: "application"
cache-control: "no-cache, no-store, max-age=0, must-revalidate"
pragma: "no-cache"
expires: "0"
x-xss-protection: "1; mode=block"
x-frame-options: "DENY"
x-content-type-options: "nosniff"
date: "Tue, 04 Dec 2018 18:54:00 GMT"
content-type: "application/json;charset=UTF-8"
transfer-encoding: "chunked"
server: "\"\""
connection: "close"
Body: {"caseId":"3c3a4448-1105-46ca-b345-4ad28f366583","results":[]}
world-checkworld-check-one
2.4k 5 5 5
@Sara.Williams
Since this is a service-affecting issue I would request you to kindly raise a ticket with our support team by using the below link,
https://my.refinitiv.com/content/mytr/en/productsupport.html?productName=Thomson%20Reuters%20World-Check%20One%20API
Regards,
Mehran Khan
2.4k 5 5 5
@Sara.Williams
Can you please provide logs for the timeout for us to investigate this further?
Regards,
Mehran Khan
