I am trying to integrate EMA in our proprietary framework, where I need to publish events and alerts should the connection to Reuters fail. I cannot seem to be able to consume such events through the OmmConsumerClient interface.
What would be the best way to receive those? Do I need to manually issue a source directory request message?
When I forcibly close the connection by terminating the VPN, I see a message in the logs but the OmmConsumerClient is not called.
Example:
2018-11-29 09:39:07,157 WARN [pool-2-thread-1] | com.thomsonreuters.ema.access.OmmConsumerImpl | | loggerMsg
Severity: Warning
Text: Received ChannelDownReconnecting event on channel Channel
RsslReactor Channel is null
Error Id 0
Internal sysError 0
Error Location Reactor.processWorkerEvent
Error text Error - exceeded initialization timeout (5 s)
loggerMsgEnd
