I am generating TickHistoryTimeAndSales on demand extractions and have noted a difference in the bahaviour of requests, depending on whether instruments get pre-validated or not.
If I do not pre-validate the instrument list, then invalid instruments get ignored and there is no record of them at all in the resulting notes file. When i do pre-validate, the notes file correctly shows permission errors associated with the instruments.
I use the following code to generate requests.
First generate a collection of InstrumentIdentifier objects from a DataTable
var reutersInstruments = from DataRow r in instrumentTable.AsEnumerable() select new InstrumentIdentifier() { Identifier = (string)r["Identifier"], IdentifierType = IdentifierType.Ric };
The following code for validating the list
var validateInstruments = context.InstrumentListOperations.ValidateIdentifiers(reutersInstruments, false);
The request is then populated in one of 2 possible ways
var request = new TickHistoryTimeAndSalesExtractionRequest { Condition = new TickHistoryTimeAndSalesCondition { ReportDateRangeType = reportDateRangeType, TimeRangeMode = timeRangeMode, QueryStartDate = queryStartDate, QueryEndDate = queryEndDate, ApplyCorrectionsAndCancellations = applyCorrectionsAndCancellations, ExtractBy = extractBy, MessageTimeStampIn = messageTimeStampIn, SortBy = sortBy, DisplaySourceRIC = displaySourceRIC }, ContentFieldNames = fields.ToArray(), IdentifierList = new InstrumentIdentifierList { // InstrumentIdentifiers = validateInstruments.ValidatedInstruments.ToArray() InstrumentIdentifiers = reutersInstruments.ToArray() }, };
The resulting requests (in JSON) and associated notes files are attached. requests.zip
I would expect the notes file to be the same in both cases.
