New sources management
In the case of WC1 API request done under a certain group for which we choose to screen against a subset of lists, how are the new sources managed ? Are they added automatically to the screening ? or we have to add them manually to the group ?
Regards
world-checkworld-check-one
4.2k 7 5 6
@nabil.hassoumi
Apologies for a delayed response and the wrong information provided.
I have got this verified and I concur that the new list added gets automatically selected for each group. So if the user does not want to include it in their search, they have to disable it manually.
4.2k 7 5 6
@nabil.hassoumi
You have to add the new list of sources to each group manually.
Kindly let me know if you need further clarification on this.
@Irfan.Khan
In the WC1 web solution, the new lists are added automatically to the OGS screening and you have to disable them if needed. I do not understand why the API should work differently.
Here is the scenario: You choose to screen against only some UK lists and disable all the other european ones. Now a new Italian list, you are not aware of but might be interested by, appeared --> It should be screened against by default until you choose to keep it or not.
Best Regards
Nabil
