Can't access Datastream from python
I want to use Datastream in python, I get an error message when I try to log in using the credentials below.
DWE =  Datastream(username="%$#%#$", password="%$#%$#")
DWE.system_info()
DWE.sources()
URLError: <urlopen error [WinError10061] No connection could be made because the
target machine actively refused it>
I have successfully imported pydatastream etc.
pythondatastream-apidsws-api
1.1k 3 3 3
@dc4311ab-5c79-4f5d-8026-dc5bb605df55
Based on above example you are not using DSWS (Datastream Web Service) but instead DWE (Dataworks Enterprise), which is not compatible with Python 3.6 and above. There is a document on the DSWS page providing overview on how to convert DWE request to DSWS: document https://developers.refinitiv.com/en/sites/default/files/Converting%20DWE%20to%20DSWS.pdf
If you don't have DSWS access I would advise to contact your Refinitiv representative.
