I see there is a lot of jobs running in DataScope Select. Many of them have been started from C# API as RawExtraction. How can I cancel them ?
@webmastertux1, do you know who / what created these jobs ? If they come from your tests, then all is fine, but if you don't know, it might be worth investigating.
You can cancel active jobs using REST API or .Net SDK.
For REST API, the job cancellation can be request by issuing a delete to the monitor URL.
DELETE https://hosted.datascopeapi.thomsonreuters.com/restapi/v1/Extractions/ExtractRawResult(ExtractionId='<job Id>')
Active Jobs can be requested by issuing the following request.
GET https://hosted.datascopeapi.reuters.com/RestApi/v1/Jobs/JobGetActive
For .Net SDK, the same functions are available. Below is the sample code which cancels all active Jobs.
jobsContext = new JobsContext(dssUri, dssUserName, dssUserPassword); var activeJobs = jobsContext.JobOperations.GetActive(); //Output the active jobs foreach (var activeJob in activeJobs.Take(10)) { System.Console.WriteLine("job: id {0}, status {1}, progress {2}, monitor url {3}", activeJob.JobId, activeJob.Status, activeJob.ProgressPercentage, activeJob.MonitorUrl); jobsContext.CancelJob(activeJob.MonitorUrl); }
For more information about Jobs, please see this key mechanism.
You can cancel an active in-progress job by submitting a DELETE to the MonitorUrl.
Or, in the case of .NET C# API, use:
ExtractionsContext.CancelJob(IAsyncJob asyncJob);
or
ExtractionsContext.CancelJob(string monitorUrl);
See the C# example application for more information on monitoring and canceling jobs.
