Could you please guide on the steps to take so that all our customers are screened daily and how to retrieve the results.
Once the case has been screened, you can use the Audit API to find out if the case has been screened.
You can use the below steps to enable OGS and then find out the updates on the cases due to OGS.
1. SEQ-case-ogs-enable: Enable ongoing screening for a case: To enable OGS on a screened case. This will tell the WC1 system to screen the case flagged with OGS everyday.
2. SEQ-case-monitor-ogs: Monitor ongoing screening updates on cases: Use this API call to retrieve the list of all case system Ids that has updates due to OGS.
3. SEQ-case-investigate-results: Get screening results: Once the case system Id has been retrieved, use this API to call each case and find out the new matches/old matches with new updates due to OGS in the case.
Kindly let me know if you need further information on this.
