Regarding the RFA API, the LoggerNotifyEvent event prints the log and does not update the data
hello
Due to network reasons, the connection is broken, and after reconnection, the following log information appears.
The message prompts that the connection has been established, but the data has not been updated and pushed, and the log information in bold below is printed.
What are the possible problems with this type of log?
********************* ERROR! ********************** ERROR! *********************
2018 Nov 03 00:44:27.864 ST GMT+08:00 2D4 2D0 570 ERROR*
<- Received LoggerNotifyEvent:
[Sat Nov 03 00:44:27 2018]: (ComponentName) Static: (Severity) Error: RSSL Channel read failed on connection "Default::Connection_RSSL1 **************:14002". Channel will be closed. (Internal debug info: "<..\..\..\Ripc\Impl\ripcsrvr.c:6654> Error:1002 ripcRead() failure. Connection reset by peer
", errno: RSSL_RET_FAILURE [0] - )
******************** WARNING! ******************** WARNING! ********************
2018 Nov 03 00:44:27.864 ST GMT+08:00 2D4 2D0 570 WARN*
[Sat Nov 03 00:44:27 2018]: (ComponentName) Static: (Severity) Warning: RSSL Channel closing on connection "Default::Connection_RSSL1 **************:14002" due to "channel read failure"
2018 Nov 03 00:44:27.864 ST GMT+08:00 2D4 2D0 570 TRACE <- Received LoggerNotifyEvent:
[Sat Nov 03 00:44:27 2018]: (ComponentName) Static: (Severity) Information: Connection Status Changed, RSSL_Cons_Connection "Default::Connection_RSSL1 **************:14002" State: "Down" StatusCode: "None" StatusText: Connection down
2018 Nov 03 00:44:27.879 ST GMT+08:00 2D4 2D0 570 TRACE <- Received LoggerNotifyEvent:
[Sat Nov 03 00:44:27 2018]: (ComponentName) Static: (Severity) Information: RSSL_Cons_Connection "Default::Connection_RSSL1 **************:14002" will be tried in 15000 milliseconds
********************** INFO ************************ INFO **********************
2018 Nov 03 00:44:28.707 ST GMT+08:00 2D4 2D0 551 INFO
Received ConnectionEvent from Connection_RSSL1. Connection is: Down
Connection Status Text: Connection down
Connection Status Code: 1.
Connection Type: RSSL
Connected Host Name : **************
Connected Port : 14002
Connected Component Version :
[0] : ezd1.2.1.L1.win.rrg 64-bit
2018 Nov 03 00:44:42.786 ST GMT+08:00 2D4 2D0 570 ERROR*
[Sat Nov 03 00:44:42 2018]: (ComponentName) Static: (Severity) Error: RSSL Channel read failed on connection "Default::Connection_RSSL **************:14002". Channel will be closed. (Internal debug info: "<..\..\..\Ripc\Impl\ripcsrvr.c:6654> Error:1002 ripcRead() failure. Connection reset by peer
2018 Nov 03 00:44:42.801 ST GMT+08:00 2D4 2D0 570 WARN*
[Sat Nov 03 00:44:42 2018]: (ComponentName) Static: (Severity) Warning: RSSL Channel closing on connection "Default::Connection_RSSL **************:14002" due to "channel read failure"
2018 Nov 03 00:44:42.801 ST GMT+08:00 2D4 2D0 570 TRACE <- Received LoggerNotifyEvent:
[Sat Nov 03 00:44:42 2018]: (ComponentName) Static: (Severity) Information: Connection Status Changed, RSSL_Cons_Connection "Default::Connection_RSSL **************:14002" State: "Down" StatusCode: "None" StatusText: Connection down
[Sat Nov 03 00:44:42 2018]: (ComponentName) Static: (Severity) Information: RSSL_Cons_Connection "Default::Connection_RSSL **************:14002" will be tried in 15000 milliseconds
2018 Nov 03 00:44:42.973 ST GMT+08:00 2D4 2D0 551 INFO
Received ConnectionEvent from Connection_RSSL. Connection is: Down
[0] : ezd1.2.1.L1.linux.rrg 64-bit
2018 Nov 03 00:44:42.973 ST GMT+08:00 2D4 2D0 648 WARN*
<- Received MMT_LOGIN Status - Login Pending
streamState : Open
dataState : Suspect
statusCode : None
statusText : Connection Down.
2018 Nov 03 00:44:42.989 ST GMT+08:00 2D4 2D0 570 TRACE <- Received LoggerNotifyEvent:
[Sat Nov 03 00:44:42 2018]: (ComponentName) Static: (Severity) Information: RSSL channel init in progress for connection "Default::Connection_RSSL1 **************:14002".
[Sat Nov 03 00:44:42 2018]: (ComponentName) Static: (Severity) Information: RSSL channel connected for connection "Default::Connection_RSSL1 **************:14002".
[Sat Nov 03 00:44:42 2018]: (ComponentName) Static: (Severity) Information: RSSL channel connected with "Requested version: 14.1, Connected version: 14.0" for connection "Default::Connection_RSSL1 **************:14002".
[Sat Nov 03 00:44:42 2018]: (ComponentName) Static: (Severity) Information: RSSL channel on connection "Default::Connection_RSSL1 **************:14002" has negotiated ping timeout set to: 30000
2018 Nov 03 00:44:43.004 ST GMT+08:00 2D4 2D0 570 TRACE <- Received LoggerNotifyEvent:
[Sat Nov 03 00:44:42 2018]: (ComponentName) Static: (Severity) Information: Connection Status Changed, RSSL_Cons_Connection "Default::Connection_RSSL1 **************:14002" State: "Up" StatusCode: "None" StatusText: Connection up
2018 Nov 03 00:44:57.911 ST GMT+08:00 2D4 2D0 570 TRACE <- Received LoggerNotifyEvent:
[Sat Nov 03 00:44:57 2018]: (ComponentName) Static: (Severity) Information: RSSL channel init in progress for connection "Default::Connection_RSSL **************:14002".
[Sat Nov 03 00:44:57 2018]: (ComponentName) Static: (Severity) Information: RSSL channel connected for connection "Default::Connection_RSSL **************:14002".
[Sat Nov 03 00:44:57 2018]: (ComponentName) Static: (Severity) Information: RSSL channel connected with "Requested version: 14.1, Connected version: 14.0" for connection "Default::Connection_RSSL **************:14002".
2018 Nov 03 00:44:57.926 ST GMT+08:00 2D4 2D0 570 TRACE <- Received LoggerNotifyEvent:
[Sat Nov 03 00:44:57 2018]: (ComponentName) Static: (Severity) Information: RSSL channel on connection "Default::Connection_RSSL **************:14002" has negotiated ping timeout set to: 30000
[Sat Nov 03 00:44:57 2018]: (ComponentName) Static: (Severity) Information: Connection Status Changed, RSSL_Cons_Connection "Default::Connection_RSSL **************:14002" State: "Up" StatusCode: "None" StatusText: Connection up
2018 Nov 03 00:44:59.942 ST GMT+08:00 2D4 2D0 551 INFO
Received ConnectionEvent from Connection_RSSL. Connection is: Up
Connection Status Text: Connection up
2018 Nov 03 00:44:59.942 ST GMT+08:00 2D4 2D0 570 WARN*
[Sat Nov 03 00:44:59 2018]: (ComponentName) Static: (Severity) Warning: Connection "Connection_RSSL" does not support Pause/Resume. Pause and Resume requests for this connection will be ignored.
[Sat Nov 03 00:44:59 2018]: (ComponentName) Static: (Severity) Warning: Connection "Connection_RSSL" does not support optimized Pause/Resume. Optimized Pause/Resume requests will be converted to individual item Pause/Resume requests for this connection.
2018 Nov 03 00:44:59.957 ST GMT+08:00 2D4 2D0 644 TRACE <- Received MMT_LOGIN Status - Login Accepted
streamState : Open
dataState : Ok
statusCode : None
statusText : Login accepted by host **************..
2018 Nov 03 00:45:12.520 ST GMT+08:00 2D4 2D0 551 INFO
Received ConnectionEvent from Connection_RSSL1. Connection is: Up
2018 Nov 03 00:45:12.536 ST GMT+08:00 2D4 2D0 570 WARN*
[Sat Nov 03 00:45:12 2018]: (ComponentName) Static: (Severity) Warning: Connection "Connection_RSSL1" does not support Pause/Resume. Pause and Resume requests for this connection will be ignored.
[Sat Nov 03 00:45:12 2018]: (ComponentName) Static: (Severity) Warning: Connection "Connection_RSSL1" does not support optimized Pause/Resume. Optimized Pause/Resume requests will be converted to individual item Pause/Resume requests for this connection.
2018 Nov 03 00:45:12.614 ST GMT+08:00 2D4 2D0 570 WARN*
[Sat Nov 03 00:45:12 2018]: (ComponentName) Static: (Severity) Warning: Received Source Name <ELEKTRON_CON> from Connection <Connection_RSSL1> is same as the one from Connection <Connection_RSSL>
[Sat Nov 03 00:45:12 2018]: (ComponentName) Static: (Severity) Warning: Received Source Name <ELEKTRON_DD> from Connection <Connection_RSSL1> is same as the one from Connection <Connection_RSSL>
treprfarfa-api
7.6k 15 6 9
@liuyi
I don't think the problem that you did not receive data related with the warning below
This warning message in RFA Logger is the warning messages which generated by RFA when it connecting to the server and it checks and found that server does not support Pause and Resume. I'm not sure that what is the item's status/stream you receive after the server is up. Normally if the item stream state is not close and if the service you are connecting is Up again you should be able to receive data.
WARNING! WARNING!
WARNING! WARNING!
-Have you received any directory update message after the service is Up again?
Just the information from the rfa.log is not enough to explain why your application did not receive the data. There could be an issue from some error on EZD server as well.
