​Problem with a local excel file that is being locked by the Thomson Reuters API
Hi, I have a problem with a local excel file that is being locked by the Thomson Reuters API. The excel file contains proprietary information and is used within the TR environment to create some graphs. When I try to update the graphs on a daily basis it says that the file is locked for editing. I close the local instance of excel. Check for any excel ghost processes and close these if open. However it still says that the file is locked upon completing this. The only way to resolve the issue appears to be closing TR. Can you provide other methods to be able to update the file without closing TR?
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonlocking
The behavior you describe is not expected. Since it is machine specific, it cannot be investigated through this forum. Troubleshooting this issue requires access to the machine where the issue is reproduced. For this reason I suggest you contact Refinitiv Helpdesk and report the problem you experience. Our Helpdesk staff can help you troubleshoot the problem. You can reach Refinitiv Helpdesk by either calling the Helpdesk number in your country or by using Contact Us capability in your Eikon application, or by submitting the support request following the link below.
https://my.refinitiv.com/content/mytr/en/productsupport.html
