secondaryFields and customFields
I would like to add a given Date of birth, nationality, passport number and a national ID number to and individual search, could you please explain how i would insert the those parameters in the secondaryFields or customFields in the contents of the request below?
{ "secondaryFields": [], "entityType": "INDIVIDUAL", "customFields": [], "groupId":"xxx", "providerTypes": [ "WATCHLIST" ], "name": "xyz" }
world-checkworld-check-onefields
2.4k 5 5 5
Hi @osama.sammour,
Please hit the "SEQ-pre-group-case-template: Get the case template for a group" API call to obtain the blueprint of available secondary fields and their definitions which you can use and form your request to further screen. Each secondary fields has a typeID mapped to it which needs to be used while forming a request for a screening!
There are 5 secondary fields available for an individual screening I am copying the same below: Passport num and nationality ID fields are not available on the API for individual screening!
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
"secondaryFieldsByEntity": {
"individual": [
"typeId": "SFCT_1",
"fieldValueType": "GENDER",
"regExp": null,
"fieldRequired": false,
"label": "GENDER"
"typeId": "SFCT_2",
"fieldValueType": "DATE",
"regExp": null,
"label": "DATE_OF_BIRTH"
"typeId": "SFCT_3",
"fieldValueType": "COUNTRY",
"regExp": null,
"label": "COUNTRY_LOCATION"
"typeId": "SFCT_4",
"regExp": null,
"label": "PLACE_OF_BIRTH"
"typeId": "SFCT_5",
"regExp": null,
"label": "NATIONALITY"
Below is a sample payload to screen an individual with secondary fields such as DOB, nationality etc.
{ "groupId":"{ {group-id}}", "entityType":"INDIVIDUAL", "providerTypes":[ "WATCHLIST" ], "name":"Barack Obama", "customFields":[], "secondaryFields":[ { "typeId":"SFCT_1", "value":"MALE" }, { "typeId":"SFCT_2", "dateTimeValue": "1961-12" }, { "typeId":"SFCT_3", "value":"USA" }, { "typeId":"SFCT_4", "value":"USA" }, { "typeId":"SFCT_5", "value":"ABW" } ] }
You can similarly add your own custom fields under the custom field tag!
Let me know if this helps!
Regards,
Mehran Khan
Thanks that very good, could you please let me know the following:
  1. What kind of custom fields can i have in the customFields array?
  2. How to upload our own private black list, which can be screened against.
Regarding to the secondaryFields
I have made a search and found a match with a DOB of 1965-01-01. but when i put in a value of secondaryFields": [{ "typeId": "SFCT_2", "dateTimeValue": "1965-01-01" }] and request results using the following URL, I keep getting a 404 not found response.
only when i change the date to be "1965-01" (without the day) i get results, but the results are just the same as with no date at all.
could you please explain/confirm:
  1. Exact date format allowed
  2. All results returned will have the given date
Regards
2.4k 5 5 5
@osama.sammour
Apologies, don't know how this was missed,
I tried screening with the same DOB I get an expected response back, please see below
Date: "Wed, 30 Oct 2019 12:54:37 GMT"
Content-Type: "application/json"
Authorization: "Signature keyId="************************",algorithm="hmac-sha256",headers="(request-target) host date content-type content-length",signature="t5eItxuhlUQ0NTR9dtH4jBsjJrhwjJfrkyIFAJXHzXM=""
Content-Length: "447"
User-Agent: "PostmanRuntime/7.19.0"
Accept: "*/*"
Cache-Control: "no-cache"
Postman-Token: "5f2b4bf9-d9a1-41a1-9fea-150143d952c3"
Host: "rms-world-check-one-api-pilot.thomsonreuters.com"
Accept-Encoding: "gzip, deflate"
Connection: "keep-alive"
Request Body
Response Headers
X-Application-Context: "application"
Cache-Control: "no-cache, no-store, max-age=0, must-revalidate"
Pragma: "no-cache"
Expires: "0"
X-XSS-Protection: "1; mode=block"
X-Frame-Options: "DENY"
X-Content-Type-Options: "nosniff"
Date: "Wed, 30 Oct 2019 12:54:38 GMT"
Content-Type: "application/json;charset=UTF-8"
Transfer-Encoding: "chunked"
Server: """"
Response Body
caseId: "f8de6cd7-2299-4039-b174-b3b6eb641946"
results: [1]
0: {…}
resultId: "0a3687d0-6d92-1a9f-9b87-2ede00ea4136"
referenceId: "e_tr_wci_259333"
matchStrength: "EXACT"
matchedTerm: "Barack OBAMA"
submittedTerm: "Barack Obama"
matchedNameType: "PRIMARY"
secondaryFieldResults: [5]
sources: [1]
categories: [1]
creationDate: "2019-10-30T12:54:38.754Z"
modificationDate: "2019-10-30T12:54:38.754Z"
primaryName: "Barack OBAMA"
events: [1]
countryLinks: [3]
identityDocuments: [0]
category: "POLITICAL INDIVIDUAL"
providerType: "WATCHLIST"
gender: "MALE"
Can you share the complete request and response of the request where you are getting a 404 ?
