Unsubscribe a ric using websocket
We are using websocket to get Market Price updates for rics such as GBP=, EUR= etc.
We send the below batch json request for an example to register multiple RIC at once in comma separated format in json field as an array:
"{\"ID\":2,\"Domain\":\"MarketPrice\",\"Key\":{\"Name\":[\"EUR=\", \"GBP=\"]}}";
We have a requirement where we need to dynamically unregister/unsubscribe to receive an update for a particular RIC, let say for "GBP=". Please can someone provide us an idea on how this can be achieved. How the JSON request will look like for unsubscribing RIC.
treprdp-apiwebsocketsrrtopricing
11.3k 25 8 13
Hi @amar04.panigrahy
You can unsubscribe a RIC using Close message. The Close message needs to contain stream ID to be closed. For more information and example, please see Batch section.
  "ID": 3,
  "Type": "Close"
For Batch request message, you can get stream ID for each item from Refresh message's Key.
RECEIVED:
    "ID": 3,
    "Type": "Refresh",
    "Key": {
      "Service": "API_ELEKTRON_EDGE_TOKYO",
      "Name": "EUR="
You can also unsubscribe multiple RICs using Batch Close.
  "ID": [
    3,
    4,
    5
  "Type": "Close"
@amar04.panigrahy, You may find this article about Websockets Batch and View feature helpful. Close request is described in the end, along with a working sample.
