How to insert AdxRtList call in synchronous code?
Hi I am following the tutorial COM APIs for use in Microsoft Office and looking at Tutorial 2 AdxRtList. I understand that after the function is called with .StartUpdates in myRtGetExample then the result is returned asynchronously via callback to the myRtGet_OnImage function. I can see this might be appropriate if e.g. updating a spreadhsheet while you keep working in it. But if you are running some code and need the AdxRtList result BEFORE proceeding any further, how do you "make it synchronous"? I have stumbled on something which seems to work but don't know if it's the correct approach. The idea is to have a Boolean module level variable called task_finished_ which I set to false before the AdxRtList call and then loop after the call until task_finished_ = True. Meanwhile the callback myRtGet_OnImage sets task_finished_ = True before exiting.
Dim WithEvents myRTGet As AdfinXRtLib.AdxRtList
Private task_finished_ As Boolean
Sub myRtGetExample()
  task_finished_ = False
  Set myRTGet = CreateAdxRtList()
  With myRTGet
    Source = "IDN"
    .RegisterItems "EUR=", "BID"
    .StartUpdates RT_MODE_IMAGE
  End With
  While Not task_finished_
    Sleep 1000
    DoEvents
    Wend
End Sub
Private Sub myRtGet_OnImage(ByVal DataStatus As AdfinXRtLib.RT_DataStatus)
  Debug.Print myRTGet.Value("EUR=", "BID")
End Sub
As I said, it seems to work but I don't know if that's the right way to do it or if there is a better approach ... Thanks
eikoneikon-com-api
4.6k 26 7 22
@george34 yep, that's one of the approaches. It depends on your task, of course, but I would still recommend using it asynchronously most of the time.
As an example of broad async approach, check out this article.
