Hello I am trying to use batch to request TREP data using ema api.
I request 9000 Rics in batch mode. I am running into this exception. Can you advise please?
Below my config file:
I tried setting the property GuaranteedOutputBuffers to 10000 and then to 100000.
<?xml version="1.0" encoding="UTF-8"?> <EmaConfig> <ChannelGroup> <ChannelList> <Channel> <Name value="Channel_1" /> <ChannelType value="ChannelType::RSSL_SOCKET" /> <GuaranteedOutputBuffers value="100000"/> <Host value="xxxxxxx" /> <Port value="14002" /> </Channel> </ChannelList> </ChannelGroup> <ConsumerGroup> <DefaultConsumer value="cunsumer1"/> <ConsumerList> <Consumer> <!-- Name is mandatory--> <Name value="cunsumer1"/> <!-- Channel is optional: defaulted to "RSSL_SOCKET+localhost+14002"--> <!-- Channel or ChannelSet may be specified --> <Channel value="Channel_1"/> <XmlTraceToStdout value="0"/> <XmlTraceToFile value="1"/> <Logger value="Logger_2"/> </Consumer> </ConsumerList> </ConsumerGroup> </EmaConfig>
