Building RFA based application with gcc-8.2.0 (c++17 standard)
Hello, team.
We are trying to build our RFA based application with latest gcc-8.2.0 (-std=c++17 standard flag) and faced with issue that the dynamic exception specifications are not allowed in ISO C++17.
rfa-7.2.1/Include/Message/RespMsg.h:245:70: error: ISO C++17 does not allow dynamic exception specifications
   void setPrincipalIdentity( const rfa::common::PrincipalIdentity& ) throw(rfa::common::InvalidUsageException);
rfa-7.2.1/Include/Message/RespMsg.h:260:107: error: ISO C++17 does not allow dynamic exception specifications
   rfa::common::UInt8 validateMsg(rfa::common::RFA_String* warningText = 0, bool isReissue = false ) const throw( rfa::common::InvalidUsageException );
Is it possible to provide C++17 compatible RFA library version?
treprfarfa-apic++build
4.4k 10 6 9
Hi @pavel.smagin
I'm afraid RFA C++ is not compatible with C++17, and there is no immediate plan to support C++17.
You can check the supported OS and compiler versions from The API Compatibility Matrix.
