can't compile Elektron-SDK1.2.1.linux on centos 7.5 with gcc 4.8.5
when I try to compile Elektron-SDK1.2.1.linux ont centos 7.5 whith gcc 4.8.5, I get the following compile log
[ 0%] Building CXX object ../googletest-build/googlemock/gtest/CMakeFiles/gtest.dir/src/gtest-all.cc.o [ 0%] Building C object Cpp-C/Eta/Applications/Examples/AuthLock/CMakeFiles/authlock.dir/rsslAuthLock.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/arrayEncoder.c.o [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/codes.c.o [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/dtime.c.o [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/arrayDecoder.c.o [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/arrayDecoder.c.o [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/dataTypes.c.o [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/dataDictionary.c.o [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/arrayEncoder.c.o [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/dataUtils.c.o [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/codes.c.o [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/dataDictionary.c.o [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/elemListEncoder.c.o [ 0%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/DOCBparser.c.o [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/elemListDecoder.c.o [ 0%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/HTMLparser.c.o [ 0%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/HTMLtree.c.o [ 0%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/SAX.c.o [ 0%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/SAX2.c.o [ 0%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/catalog.c.o [ 0%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/chvalid.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 0%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/c14n.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/filterListDecoder.c.o [ 0%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/filterListEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 1%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/fieldListDecoder.c.o [ 1%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/fieldListEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 2%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/dataTypes.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 2%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/mapDecoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 2%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/dataUtils.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 2%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/authlock [ 2%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/dict.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 2%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/numeric.c.o [ 2%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/mapEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 2%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/dtime.c.o [ 2%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/primitiveDecoders.c.o [ 2%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/elemListDecoder.c.o [ 2%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/encoding.c.o [ 2%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/debugXML.c.o [ 2%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/primitiveEncoders.c.o [ 2%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/elemListEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 2%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/rsslCharSet.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 2%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/rsslcnvtab.c.o [ 2%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/rsslRmtes.c.o [ 3%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/entities.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 3%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/rwfConvert.c.o [ 3%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/error.c.o [ 3%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/fieldListDecoder.c.o [ 3%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/fieldListEncoder.c.o [ 3%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/seriesDecoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 3%] Built target authlock cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/seriesEncoder.c.o [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/filterListDecoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/globals.c.o [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/filterListEncoder.c.o [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/setDictionary.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/state.c.o [ 4%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/hash.c.o [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/mapDecoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/vectorDecoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/messageDecoders.c.o [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/messageEncoders.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/vectorEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/msgs.c.o [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/decodeRoutines.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/dictionary.c.o [ 4%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/legacy.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/list.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/numeric.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/primitiveDecoders.c.o [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/mapEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/fieldListDefs.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/nanoftp.c.o [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/xmlDomainDump.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/primitiveEncoders.c.o [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/rsslCharSet.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/nanohttp.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/xmlDump.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/xmlMsgDump.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 4%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/parserInternals.c.o [ 4%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/parser.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 5%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/rsslcnvtab.c.o [ 5%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/rsslRmtes.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 6%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Transport/ripchttp.c.o [ 6%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Transport/ripccomp.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 6%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Transport/ripcssldh.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 6%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/pattern.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 6%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/relaxng.c.o [ 6%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/rwfConvert.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 6%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/seriesDecoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 6%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Transport/ripcsslutils.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 6%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Transport/ripcutils.c.o [ 6%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/threads.c.o [ 6%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/schematron.c.o [ 6%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/seriesEncoder.c.o [ 7%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/tree.c.o [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Transport/rsslUniShMemTransportImpl.c.o [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Transport/rsslSocketTransportImpl.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Transport/rsslSeqMcastTransportImpl.c.o [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Transport/rsslImpl.c.o [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/setDictionary.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Transport/shmemtrans.c.o [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/state.c.o [ 7%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/uri.c.o [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/vectorDecoder.c.o [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Util/cutildfltcbuffer.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Util/cutilsmplcbuffer.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Util/rsslHashTable.c.o [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Util/rsslMemoryBuffer.c.o [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/vectorEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 7%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/valid.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 7%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xinclude.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 7%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Util/rsslNotifier.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 7%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xlink.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 7%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xmlIO.c.o [ 8%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Util/shmem.c.o [ 8%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/messageDecoders.c.o [ 8%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/messageEncoders.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 8%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xmlmemory.c.o [ 8%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Util/tr_sha_1.c.o [ 8%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Util/shmemcirbuf.c.o [ 8%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/Util/tr_sl1_64.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 8%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xmlmodule.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 8%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/decodeRoutines.c.o [ 8%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/msgs.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 8%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/dictionary.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 8%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/__/Utils/Lzf/lz4.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 8%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xmlreader.c.o [ 8%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/__/Utils/zlib/adler32.c.o [ 8%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/__/Utils/zlib/compress.c.o [ 8%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/__/Utils/zlib/crc32.c.o [ 9%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/fieldListDefs.c.o [ 9%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xmlregexp.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 9%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xmlsave.c.o [ 9%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/__/Utils/zlib/deflate.c.o [ 9%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/__/Utils/zlib/infback.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 9%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/__/Utils/zlib/gzio.c.o [ 9%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/xmlDomainDump.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 9%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xmlschemas.c.o [ 9%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/__/Utils/zlib/inffast.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 9%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/xmlMsgDump.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 9%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/xmlDump.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 9%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Transport/ripccomp.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 9%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xmlschemastypes.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 9%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/__/Utils/zlib/inflate.c.o [ 9%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xmlstring.c.o [ 9%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/__/Utils/zlib/inftrees.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 9%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Transport/ripcssldh.c.o [ 9%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xmlunicode.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 9%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Transport/ripchttp.c.o [ 9%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xpath.c.o [ 10%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xmlwriter.c.o [ 10%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/__/Utils/zlib/trees.c.o [ 10%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Transport/ripcsslutils.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 11%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/__/Utils/zlib/uncompr.c.o [ 11%] Building C object Cpp-C/Eta/Utils/Libxml2/CMakeFiles/libxml2.dir/xpointer.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 11%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Transport/ripcutils.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 11%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/__/__/Utils/zlib/zutil.c.o [ 11%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Transport/rsslImpl.c.o [ 11%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl_shared.dir/rsslVersionShared.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 11%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Transport/rsslSeqMcastTransportImpl.c.o [ 11%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Transport/rsslSocketTransportImpl.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 11%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Util/cutildfltcbuffer.c.o [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Util/cutilsmplcbuffer.c.o [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Util/rsslHashTable.c.o [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Util/rsslMemoryBuffer.c.o [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Util/rsslNotifier.c.o [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Transport/rsslUniShMemTransportImpl.c.o [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Transport/shmemtrans.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Util/shmem.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Util/shmemcirbuf.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Util/tr_sha_1.c.o [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/Util/tr_sl1_64.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/__/Utils/Lzf/lz4.c.o [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/__/Utils/zlib/adler32.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/__/Utils/zlib/compress.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/__/Utils/zlib/crc32.c.o [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/__/Utils/zlib/deflate.c.o [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/__/Utils/zlib/gzio.c.o [ 12%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/__/Utils/zlib/infback.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 13%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/__/Utils/zlib/inffast.c.o [ 13%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/__/Utils/zlib/inflate.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 13%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/__/Utils/zlib/inftrees.c.o [ 13%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/__/Utils/zlib/trees.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 13%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/__/Utils/zlib/uncompr.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 13%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/rsslVersionStatic.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 13%] Building C object Cpp-C/Eta/Impl/Codec/CMakeFiles/librssl.dir/__/__/Utils/zlib/zutil.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 13%] Linking C shared library ../../../../../Cpp-C/Eta/Libs/CENTOS7_64_GCC482/Optimized/Shared/librssl.so [ 13%] Built target librssl_shared [ 13%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_1c_ReadWrite/CMakeFiles/ConsMod1c_shared.dir/UPAConsumer_Training.c.o [ 13%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_1b_Ping/CMakeFiles/ConsMod1b_shared.dir/UPAConsumer_Training.c.o [ 13%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_3_Directory/CMakeFiles/ConsMod3_shared.dir/UPAConsumer_Training.c.o [ 13%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_1a_Connect/CMakeFiles/ConsMod1a_shared.dir/UPAConsumer_Training.c.o [ 13%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_2_Login/CMakeFiles/ConsMod2_shared.dir/UPAConsumer_Training.c.o [ 13%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_4_Dictionary/CMakeFiles/ConsMod4_shared.dir/UPAConsumer_Training.c.o [ 13%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_5_ItemRequest/CMakeFiles/ConsMod5_shared.dir/UPAConsumer_Training.c.o [ 13%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_1a_Connect/CMakeFiles/NIProvMod1a_shared.dir/UPANIProvider_Training.c.o [ 13%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_1b_Ping/CMakeFiles/NIProvMod1b_shared.dir/UPANIProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 13%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_1c_ReadWrite/CMakeFiles/NIProvMod1c_shared.dir/UPANIProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 13%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_2_Login/CMakeFiles/NIProvMod2_shared.dir/UPANIProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 13%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_3_ProvideDirectory/CMakeFiles/NIProvMod3_shared.dir/UPANIProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 13%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_4_Dictionary/CMakeFiles/NIProvMod4_shared.dir/UPANIProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 13%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_1b_Ping/CMakeFiles/ProvMod1b_shared.dir/UPAProvider_Training.c.o [ 13%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_1a_Connect/CMakeFiles/ProvMod1a_shared.dir/UPAProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 14%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_5_ProvideContent/CMakeFiles/NIProvMod5_shared.dir/UPANIProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 14%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/TunnelStream/bigBufferPool.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 14%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_1c_ReadWrite/CMakeFiles/ProvMod1c_shared.dir/UPAProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 14%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/TunnelStream/bufferPool.c.o [ 14%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/Watchlist/rsslWatchlistImpl.c.o [ 14%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/TunnelStream/rsslTunnelStream.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 14%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/TunnelStream/msgQueueEncDec.c.o [ 14%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/TunnelStream/tunnelManager.c.o [ 14%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/TunnelStream/rsslRDMQueueMsgInt.c.o [ 15%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/TunnelStream/tunnelStreamImpl.c.o [ 15%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/TunnelStream/tunnelSubstream.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 15%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/TunnelStream/persistFile.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 15%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProvMod1a cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 15%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_2_HandleLogin/CMakeFiles/ProvMod2_shared.dir/UPAProvider_Training.c.o [ 15%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ConsMod1b [ 16%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProvMod1c cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 16%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_3_ProvideDirectory/CMakeFiles/ProvMod3_shared.dir/UPAProvider_Training.c.o [ 16%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_4_ProvideDictionary/CMakeFiles/ProvMod4_shared.dir/UPAProvider_Training.c.o [ 16%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ConsMod1c [ 16%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProvMod1b cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 16%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ConsMod1a cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 16%] Built target NIProvMod1a_shared [ 16%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_5_HandleItemRequest/CMakeFiles/ProvMod5_shared.dir/UPAProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 16%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ConsMod2 [ 16%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ProvMod1b cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 16%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ProvMod1a [ 16%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProvMod3 [ 16%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/Watchlist/wlBase.c.o [ 16%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/Watchlist/wlDirectory.c.o [ 16%] Built target ConsMod1b_shared [ 16%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/Watchlist/wlItem.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 16%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/rsslConsumer.c.o [ 16%] Built target NIProvMod1c_shared [ 16%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample_shared.dir/elementListEncDec.c.o [ 16%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample_shared.dir/fieldListEncDec.c.o [ 16%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ProvMod1c [ 16%] Built target ConsMod1a_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 16%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample_shared.dir/filterListEncDec.c.o [ 16%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProvMod2 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 16%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample_shared.dir/rsslEncDecExample.c.o [ 16%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample_shared.dir/msgEncDec.c.o [ 17%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ConsMod3 [ 17%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/rsslDictionaryHandler.c.o [ 17%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample_shared.dir/mapEncDec.c.o [ 17%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/rsslDirectoryHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 17%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/rsslMarketPriceHandler.c.o [ 17%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ConsMod4 [ 17%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/Watchlist/wlLogin.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 17%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/Watchlist/wlMsgReorderQueue.c.o [ 17%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample_shared.dir/vectorEncDec.c.o [ 17%] Built target ConsMod1c_shared [ 17%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample_shared.dir/seriesEncDec.c.o [ 17%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/Watchlist/wlPostIdTable.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 17%] Built target NIProvMod1b_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 17%] Built target ConsMod2_shared [ 17%] Built target ProvMod1a_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 17%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/Watchlist/wlService.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 17%] Built target NIProvMod3_shared [ 17%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ProvMod2 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 17%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProvMod4 [ 17%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/Watchlist/wlServiceCache.c.o [ 17%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/rsslMarketByOrderHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 17%] Built target ProvMod1b_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 18%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/rsslMarketByPriceHandler.c.o [ 18%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/Watchlist/wlSymbolList.c.o [ 18%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/Watchlist/wlView.c.o [ 18%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ConsMod5 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 18%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider_shared.dir/rsslDirectoryHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 18%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/rsslSymbolListHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 18%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/rsslReactor.c.o [ 19%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider_shared.dir/rsslItemHandler.c.o [ 19%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProvMod5 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 19%] Built target NIProvMod2_shared [ 19%] Built target ConsMod3_shared [ 19%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/rsslReactorWorker.c.o [ 19%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/rsslYieldCurveHandler.c.o [ 19%] Linking C static library ../../../../../Cpp-C/Eta/Libs/CENTOS7_64_GCC482/Optimized/librssl.a cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 19%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/rsslPostHandler.c.o [ 19%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider_shared.dir/rsslNIProvider.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/__/RDM/rsslRDMDictionaryMsg.c.o [ 20%] Built target ConsMod4_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/__/RDM/rsslRDMDirectoryMsg.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider_shared.dir/__/Common/rsslDictionaryProvider.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Built target ProvMod1c_shared [ 20%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider_shared.dir/__/Common/rsslItemEncode.c.o [ 20%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider_shared.dir/__/Common/rsslDirectoryEncodeDecode.c.o [ 20%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/__/RDM/rsslRDMLoginMsg.c.o [ 20%] Built target ProvMod2_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/EncDecExample [ 20%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/__/RDM/rsslRDMQueueMsg.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Built target NIProvMod4_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/__/Common/rsslLoginConsumer.c.o [ 20%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/__/Common/rsslDirectoryEncodeDecode.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/__/Common/rsslLoginEncodeDecode.c.o [ 20%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider_shared.dir/__/Common/rsslLoginConsumer.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ProvMod4 [ 20%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider_shared.dir/rsslDirectoryHandler.c.o [ 20%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/__/Common/rsslSendMessage.c.o [ 20%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider_shared.dir/rsslItemHandler.c.o [ 20%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA_shared.dir/rsslVAVersionShared.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Built target ConsMod5_shared [ 20%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer_shared.dir/__/Common/rsslMarketPriceItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider_shared.dir/__/Common/rsslLoginEncodeDecode.c.o [ 20%] Built target librssl cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Built target NIProvMod5_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider_shared.dir/__/Common/rsslMarketPriceItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider_shared.dir/__/Common/rsslMarketByOrderItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 20%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider_shared.dir/__/Common/rsslSendMessage.c.o [ 20%] Built target EncDecExample_shared [ 20%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider_shared.dir/rsslLoginHandler.c.o [ 20%] Built target ProvMod4_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 21%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider_shared.dir/rsslProvider.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 21%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/TunnelStream/bigBufferPool.c.o [ 21%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/TunnelStream/msgQueueEncDec.c.o [ 22%] Building C object Cpp-C/Eta/Impl/EtaJni/CMakeFiles/libEtaJni_shared.dir/Impl/JniTransport.c.o [ 22%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider_shared.dir/__/Common/rsslDirectoryEncodeDecode.c.o [ 22%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_1a_Connect/CMakeFiles/ConsMod1a.dir/UPAConsumer_Training.c.o [ 22%] Building C object Cpp-C/Eta/Impl/EtaJni/CMakeFiles/libEtaJni_shared.dir/Impl/rsslEtaJNIVersionShared.c.o [ 22%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/TunnelStream/bufferPool.c.o [ 22%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider_shared.dir/__/Common/rsslItemEncode.c.o [ 23%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ProvMod3 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 23%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_1b_Ping/CMakeFiles/ConsMod1b.dir/UPAConsumer_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 23%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/TunnelStream/persistFile.c.o [ 23%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider_shared.dir/__/Common/rsslLoginEncodeDecode.c.o [ 23%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_1c_ReadWrite/CMakeFiles/ConsMod1c.dir/UPAConsumer_Training.c.o [ 23%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/TunnelStream/rsslRDMQueueMsgInt.c.o [ 23%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_4_Dictionary/CMakeFiles/ConsMod4.dir/UPAConsumer_Training.c.o [ 23%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_2_Login/CMakeFiles/ConsMod2.dir/UPAConsumer_Training.c.o [ 23%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ProvMod5 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 23%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider_shared.dir/__/Common/rsslMarketByOrderItems.c.o [ 23%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_3_Directory/CMakeFiles/ConsMod3.dir/UPAConsumer_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 23%] Building C object Cpp-C/Eta/Applications/Training/Consumer/Module_5_ItemRequest/CMakeFiles/ConsMod5.dir/UPAConsumer_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 23%] Built target ProvMod3_shared [ 23%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/TunnelStream/rsslTunnelStream.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 23%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider_shared.dir/__/Common/rsslMarketByPriceItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 23%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider_shared.dir/__/Common/rsslMarketPriceItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 23%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider_shared.dir/__/Common/rsslSendMessage.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 23%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_1a_Connect/CMakeFiles/NIProvMod1a.dir/UPANIProvider_Training.c.o [ 23%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider_shared.dir/__/Common/rsslSymbolListItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 23%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ConsMod1a [ 24%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/TunnelStream/tunnelManager.c.o [ 24%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/Consumer cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 24%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider_shared.dir/__/Common/rsslDictionaryProvider.c.o [ 24%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_1b_Ping/CMakeFiles/NIProvMod1b.dir/UPANIProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 24%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/TunnelStream/tunnelStreamImpl.c.o [ 24%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_3_ProvideDirectory/CMakeFiles/NIProvMod3.dir/UPANIProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 24%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_1c_ReadWrite/CMakeFiles/NIProvMod1c.dir/UPANIProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 24%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_2_Login/CMakeFiles/NIProvMod2.dir/UPANIProvider_Training.c.o [ 25%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ConsMod1b [ 25%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/TunnelStream/tunnelSubstream.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 25%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_4_Dictionary/CMakeFiles/NIProvMod4.dir/UPANIProvider_Training.c.o [ 25%] Built target ProvMod5_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 25%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/Watchlist/rsslWatchlistImpl.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 25%] Building C object Cpp-C/Eta/Applications/Training/NIProvider/Module_5_ProvideContent/CMakeFiles/NIProvMod5.dir/UPANIProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 25%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProvider cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 25%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/Watchlist/wlBase.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 25%] Built target Consumer_shared [ 25%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/Watchlist/wlDirectory.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 25%] Built target ConsMod1b [ 25%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ConsMod1c cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 25%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_1a_Connect/CMakeFiles/ProvMod1a.dir/UPAProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 25%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/Watchlist/wlItem.c.o [ 26%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_1b_Ping/CMakeFiles/ProvMod1b.dir/UPAProvider_Training.c.o [ 26%] Linking C static library ../../../../../Cpp-C/Eta/Libs/CENTOS7_64_GCC482/Optimized/libxml2.a [ 26%] Built target ConsMod1a cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 26%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/NIProvMod1a [ 26%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/Watchlist/wlMsgReorderQueue.c.o [ 26%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_1c_ReadWrite/CMakeFiles/ProvMod1c.dir/UPAProvider_Training.c.o [ 26%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/Watchlist/wlLogin.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 26%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_2_HandleLogin/CMakeFiles/ProvMod2.dir/UPAProvider_Training.c.o [ 26%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/Watchlist/wlPostIdTable.c.o [ 26%] Built target NIProvider_shared [ 26%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ConsMod2 [ 26%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/NIProvMod1c cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 26%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_3_ProvideDirectory/CMakeFiles/ProvMod3.dir/UPAProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 26%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/NIProvMod1b [ 26%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/Watchlist/wlService.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 26%] Built target libxml2 [ 26%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/Watchlist/wlServiceCache.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 26%] Built target ConsMod1c [ 26%] Built target NIProvMod1a [ 26%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/Watchlist/wlSymbolList.c.o [ 26%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_4_ProvideDictionary/CMakeFiles/ProvMod4.dir/UPAProvider_Training.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 26%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ProvMod1a [ 26%] Building C object Cpp-C/Eta/Applications/Training/Provider/Module_5_HandleItemRequest/CMakeFiles/ProvMod5.dir/UPAProvider_Training.c.o [ 26%] Built target ConsMod2 [ 26%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/Watchlist/wlView.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 26%] Built target NIProvMod1c [ 26%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/rsslReactor.c.o [ 27%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/rsslReactorWorker.c.o [ 27%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/NIProvMod3 [ 27%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/rsslConsumer.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 27%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/__/RDM/rsslRDMDictionaryMsg.c.o [ 27%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/rsslDictionaryHandler.c.o [ 27%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample.dir/elementListEncDec.c.o [ 27%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/NIProvMod2 [ 27%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider.dir/rsslDirectoryHandler.c.o [ 27%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider.dir/rsslItemHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 27%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/rsslMarketByOrderHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 27%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample.dir/filterListEncDec.c.o [ 27%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample.dir/fieldListEncDec.c.o [ 28%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/rsslMarketByPriceHandler.c.o [ 28%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/rsslMarketPriceHandler.c.o [ 28%] Built target NIProvMod1b [ 28%] Built target ProvMod1a [ 28%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider.dir/rsslNIProvider.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/rsslDirectoryHandler.c.o [ 28%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample.dir/mapEncDec.c.o [ 28%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/rsslSymbolListHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider.dir/__/Common/rsslDictionaryProvider.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ConsMod4 [ 28%] Linking C shared library ../../../../../Cpp-C/Eta/Libs/CENTOS7_64_GCC482/Optimized/Shared/librsslUpaJNI.so [ 28%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/__/RDM/rsslRDMDirectoryMsg.c.o [ 28%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/NIProvMod4 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ProvMod1b cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample.dir/msgEncDec.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/__/RDM/rsslRDMQueueMsg.c.o [ 28%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample.dir/rsslEncDecExample.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider.dir/__/Common/rsslDirectoryEncodeDecode.c.o [ 28%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/NIProvMod5 [ 28%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/__/RDM/rsslRDMLoginMsg.c.o [ 28%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider.dir/rsslDirectoryHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider.dir/rsslItemHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Built target NIProvMod3 [ 28%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider.dir/__/Common/rsslItemEncode.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/Provider cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Building C object Cpp-C/Eta/Impl/Reactor/CMakeFiles/librsslVA.dir/rsslVAVersionStatic.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ConsMod5 [ 28%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ProvMod1c cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/rsslYieldCurveHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 28%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample.dir/seriesEncDec.c.o [ 28%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider.dir/__/Common/rsslLoginConsumer.c.o [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider.dir/rsslLoginHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider.dir/__/Common/rsslLoginEncodeDecode.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider.dir/rsslProvider.c.o [ 29%] Building C object Cpp-C/Eta/Applications/Examples/EncDecExample/CMakeFiles/EncDecExample.dir/vectorEncDec.c.o [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/rsslPostHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Built target NIProvMod2 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider.dir/__/Common/rsslDirectoryEncodeDecode.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider.dir/__/Common/rsslMarketByOrderItems.c.o [ 29%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ProvMod2 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ConsMod3 [ 29%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider.dir/__/Common/rsslMarketPriceItems.c.o [ 29%] Built target NIProvMod4 [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/__/Common/rsslDirectoryEncodeDecode.c.o [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/__/Common/rsslLoginConsumer.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Built target libEtaJni_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider.dir/__/Common/rsslItemEncode.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider.dir/__/Common/rsslLoginEncodeDecode.c.o [ 29%] Built target ConsMod4 [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider.dir/__/Common/rsslMarketByOrderItems.c.o [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/__/Common/rsslLoginEncodeDecode.c.o [ 29%] Built target ProvMod1b cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Building C object Cpp-C/Eta/Applications/Examples/NIProvider/CMakeFiles/NIProvider.dir/__/Common/rsslSendMessage.c.o [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/__/Common/rsslSendMessage.c.o [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Consumer/CMakeFiles/Consumer.dir/__/Common/rsslMarketPriceItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Built target Provider_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Built target ConsMod5 [ 29%] Built target ProvMod1c cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ProvMod3 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider.dir/__/Common/rsslMarketByPriceItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Built target NIProvMod5 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider.dir/__/Common/rsslMarketPriceItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider.dir/__/Common/rsslSendMessage.c.o [ 29%] Built target ProvMod2 [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider.dir/__/Common/rsslSymbolListItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Built target ConsMod3 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 29%] Building C object Cpp-C/Eta/Applications/Examples/Provider/CMakeFiles/Provider.dir/__/Common/rsslDictionaryProvider.c.o [ 29%] Built target ProvMod3 [ 30%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/EncDecExample cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 30%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/NIProvider [ 30%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ProvMod4 [ 30%] Linking C shared library ../../../../../Cpp-C/Eta/Libs/CENTOS7_64_GCC482/Optimized/Shared/librsslVA.so [ 30%] Built target EncDecExample [ 30%] Built target librsslVA_shared [ 30%] Built target NIProvider [ 30%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Consumer [ 30%] Building C object Cpp-C/Eta/Applications/Examples/WatchlistConsumer/CMakeFiles/WatchlistConsumer_shared.dir/itemDecoder.c.o [ 30%] Building C object Cpp-C/Eta/Applications/Examples/WatchlistConsumer/CMakeFiles/WatchlistConsumer_shared.dir/rsslWatchlistConsumer.c.o [ 31%] Building C object Cpp-C/Eta/Applications/Examples/WatchlistConsumer/CMakeFiles/WatchlistConsumer_shared.dir/watchlistConsumerConfig.c.o [ 31%] Building C object Cpp-C/Eta/Applications/Examples/WatchlistConsumer/CMakeFiles/WatchlistConsumer_shared.dir/postHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 31%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider_shared.dir/rsslNIProvider.c.o [ 31%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider_shared.dir/rsslNILoginProvider.c.o [ 31%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider_shared.dir/rsslNIDirectoryProvider.c.o [ 31%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/rsslConsumer.c.o [ 31%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/consumerThreads.c.o [ 31%] Building C object Cpp-C/Eta/Applications/Examples/WatchlistConsumer/CMakeFiles/WatchlistConsumer_shared.dir/__/VACommon/simpleTunnelMsgHandler.c.o [ 31%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/marketByOrderDecoder.c.o [ 31%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/consPerfConfig.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 31%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider_shared.dir/rsslNIItemHandler.c.o [ 31%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/marketPriceDecoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 31%] Building C object Cpp-C/Eta/Applications/Examples/WatchlistConsumer/CMakeFiles/WatchlistConsumer_shared.dir/__/VACommon/tunnelStreamHandler.c.o [ 31%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf_shared.dir/niProvPerfConfig.c.o [ 31%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf_shared.dir/__/Common/getTime.c.o [ 31%] Built target ProvMod4 [ 32%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/__/Common/channelHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 32%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf_shared.dir/__/Common/directoryProvider.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 32%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf_shared.dir/__/Common/channelHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 32%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/upacConsPerf.c.o [ 32%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf_shared.dir/upacNIProvPerf.c.o [ 33%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/rsslDictionaryHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 33%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/__/Common/getTime.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 33%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf_shared.dir/__/Common/itemEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 33%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/rsslDictionaryProvider.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 33%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider_shared.dir/rsslVANIMarketByOrderItems.c.o [ 33%] Linking C executable ../../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ProvMod5 cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 33%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/rsslDirectoryHandler.c.o [ 34%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider_shared.dir/rsslVANIMarketPriceItems.c.o [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/dictionaryProvider.c.o [ 34%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Provider [ 34%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider_shared.dir/__/VACommon/rsslVACacheHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Built target Consumer cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf_shared.dir/transportPerfConfig.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/__/Common/itemEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/rsslDirectoryHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/__/Common/latencyRandomArray.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf_shared.dir/transportThreads.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/rsslLoginHandler.c.o [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf_shared.dir/__/Common/latencyRandomArray.c.o [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/provPerfConfig.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/loginProvider.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/rsslItemHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider_shared.dir/__/VACommon/rsslVASendMessage.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/__/Common/marketByOrderEncoder.c.o [ 34%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/rsslLoginConsumer.c.o [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf_shared.dir/__/Common/marketByOrderEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/__/Common/marketPriceEncoder.c.o [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf_shared.dir/upacTransportPerf.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/upacProvPerf.c.o [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf_shared.dir/__/Common/marketPriceEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf_shared.dir/__/Common/channelHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 34%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/rsslProvider.c.o [ 34%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/rsslMarketByOrderHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/__/Common/channelHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf_shared.dir/__/Common/providerThreads.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/__/Common/statistics.c.o [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf_shared.dir/__/Common/statistics.c.o [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf_shared.dir/__/Common/latencyRandomArray.c.o [ 35%] Built target ProvMod5 [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf_shared.dir/__/Common/getTime.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/__/VACommon/rsslVAMarketPriceItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/__/Common/directoryProvider.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/AckMsg.cpp.o [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/__/VACommon/rsslVAMarketByOrderItems.c.o [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/rsslMarketByPriceHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/__/Common/xmlItemListParser.c.o [ 35%] Built target Provider [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf_shared.dir/__/Common/xmlMsgDataParser.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/rsslMarketPriceHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/__/Common/getTime.c.o [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf_shared.dir/__/Common/statistics.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf_shared.dir/__/Common/xmlItemListParser.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Attrib.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/__/Common/itemEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/VANIProvider cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/__/VACommon/rsslVAMarketByPriceItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf_shared.dir/__/Common/xmlMsgDataParser.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/WatchlistConsumer [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/rsslPostHandler.c.o [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/__/VACommon/rsslVASymbolListItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/rsslSymbolListHandler.c.o [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/__/Common/latencyRandomArray.c.o [ 35%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/AckMsgDecoder.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/rsslYieldCurveHandler.c.o [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/__/VACommon/rsslVACacheHandler.c.o [ 35%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/AckMsgEncoder.cpp.o [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/__/VACommon/rsslVAItemEncode.c.o [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/__/Common/marketByOrderEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/__/VACommon/rsslVAMarketPriceItems.c.o [ 35%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/__/Common/marketPriceEncoder.c.o [ 35%] Built target VANIProvider_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/__/VACommon/simpleTunnelMsgHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 35%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/__/VACommon/tunnelStreamHandler.c.o [ 35%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ActiveConfig.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 36%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/__/VACommon/rsslVASendMessage.c.o [ 36%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/__/VACommon/rsslVACacheHandler.c.o [ 36%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ClientSession.cpp.o [ 36%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ChannelCallbackClient.cpp.o [ 36%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/__/Common/statistics.c.o [ 36%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/__/Common/providerThreads.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 36%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/__/Common/xmlItemListParser.c.o [ 36%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer_shared.dir/__/VACommon/rsslVASendMessage.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 36%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/__/VACommon/simpleTunnelMsgHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 36%] Built target WatchlistConsumer_shared [ 36%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider_shared.dir/__/VACommon/tunnelStreamHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 36%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ComplexType.cpp.o [ 37%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Data.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 37%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf_shared.dir/__/Common/xmlMsgDataParser.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 37%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/DataType.cpp.o [ 37%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/TransportPerf [ 37%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/DateTimeStringFormat.cpp.o [ 37%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/DictionaryCallbackClient.cpp.o [ 37%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Decoder.cpp.o [ 37%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/DictionaryHandler.cpp.o [ 37%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/DirectoryServiceStore.cpp.o [ 37%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/DirectoryCallbackClient.cpp.o [ 37%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/DirectoryHandler.cpp.o [ 37%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ElementEntry.cpp.o [ 37%] Built target TransportPerf_shared [ 37%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ElementList.cpp.o [ 38%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/EmaBufferInt.cpp.o [ 38%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ElementListDecoder.cpp.o [ 38%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/EmaBuffer.cpp.o [ 38%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ElementListEncoder.cpp.o [ 38%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ElementListSetDef.cpp.o [ 38%] Linking C static library ../../../../../Cpp-C/Eta/Libs/CENTOS7_64_GCC482/Optimized/librsslVA.a [ 38%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/VAProvider [ 38%] Built target librsslVA [ 38%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/EmaBufferU16.cpp.o [ 39%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/VAConsumer [ 39%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/EmaBufferU16Int.cpp.o [ 39%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/EmaPool.cpp.o [ 39%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/EmaString.cpp.o [ 39%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/EmaStringInt.cpp.o [ 39%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/EmaStaticCombined.cpp.o [ 39%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Encoder.cpp.o [ 39%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/EmaConfigImpl.cpp.o [ 39%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/EncodeIterator.cpp.o [ 39%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/rsslDictionaryProvider.c.o [ 39%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/rsslDirectoryHandler.c.o [ 39%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/rsslConsumer.c.o [ 39%] Built target VAConsumer_shared [ 39%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ErrorClientHandler.cpp.o [ 39%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/rsslProvider.c.o [ 39%] Built target VAProvider_shared cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 39%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/__/VACommon/rsslVAMarketPriceItems.c.o [ 39%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ConsPerf [ 39%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/rsslLoginHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 39%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/rsslItemHandler.c.o [ 39%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ExceptionTranslator.cpp.o [ 39%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/rsslDictionaryHandler.c.o [ 39%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/FieldListEncoder.cpp.o [ 39%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/FieldList.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 39%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider.dir/rsslNIProvider.c.o [ 40%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/rsslDirectoryHandler.c.o [ 40%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider.dir/rsslNILoginProvider.c.o [ 40%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/FieldEntry.cpp.o [ 41%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/FieldListDecoder.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 41%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/__/VACommon/rsslVAMarketByOrderItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 41%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider.dir/rsslNIDirectoryProvider.c.o [ 41%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/rsslLoginConsumer.c.o [ 42%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProvPerf [ 42%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider.dir/rsslNIItemHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 42%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/__/VACommon/rsslVAMarketByPriceItems.c.o [ 42%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/rsslMarketByOrderHandler.c.o [ 42%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider.dir/rsslVANIMarketByOrderItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 42%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/__/VACommon/rsslVASymbolListItems.c.o [ 42%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/FieldListSetDef.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 42%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/FilterEntry.cpp.o [ 42%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider.dir/rsslVANIMarketPriceItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 42%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/rsslMarketByPriceHandler.c.o [ 42%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/FilterListDecoder.cpp.o [ 42%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/FilterList.cpp.o [ 42%] Building C object Cpp-C/Eta/Applications/Examples/WatchlistConsumer/CMakeFiles/WatchlistConsumer.dir/itemDecoder.c.o [ 42%] Built target ConsPerf_shared [ 42%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/consPerfConfig.c.o [ 42%] Building C object Cpp-C/Eta/Applications/Examples/WatchlistConsumer/CMakeFiles/WatchlistConsumer.dir/postHandler.c.o [ 42%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/marketByOrderDecoder.c.o [ 42%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/marketPriceDecoder.c.o [ 42%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/consumerThreads.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 42%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider.dir/__/VACommon/rsslVACacheHandler.c.o [ 42%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/rsslMarketPriceHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 42%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf.dir/niProvPerfConfig.c.o [ 42%] Building C object Cpp-C/Eta/Applications/Examples/VANIProvider/CMakeFiles/VANIProvider.dir/__/VACommon/rsslVASendMessage.c.o [ 42%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/FilterListEncoder.cpp.o [ 42%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/__/VACommon/rsslVAItemEncode.c.o [ 43%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/__/VACommon/rsslVASendMessage.c.o [ 43%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/dictionaryProvider.c.o [ 43%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf.dir/upacNIProvPerf.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 43%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/loginProvider.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 43%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/__/VACommon/rsslVACacheHandler.c.o [ 43%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/rsslPostHandler.c.o [ 43%] Building C object Cpp-C/Eta/Applications/Examples/WatchlistConsumer/CMakeFiles/WatchlistConsumer.dir/rsslWatchlistConsumer.c.o [ 43%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/upacConsPerf.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 43%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/__/VACommon/simpleTunnelMsgHandler.c.o [ 43%] Building C object Cpp-C/Eta/Applications/Examples/WatchlistConsumer/CMakeFiles/WatchlistConsumer.dir/watchlistConsumerConfig.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 43%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf.dir/__/Common/channelHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 43%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/provPerfConfig.c.o [ 43%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/rsslSymbolListHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 43%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/upacProvPerf.c.o [ 43%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/__/Common/channelHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 43%] Built target NIProvPerf_shared [ 43%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/GenericMsg.cpp.o [ 43%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf.dir/__/Common/directoryProvider.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 43%] Building C object Cpp-C/Eta/Applications/Examples/WatchlistConsumer/CMakeFiles/WatchlistConsumer.dir/__/VACommon/simpleTunnelMsgHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 43%] Building C object Cpp-C/Eta/Applications/Examples/WatchlistConsumer/CMakeFiles/WatchlistConsumer.dir/__/VACommon/tunnelStreamHandler.c.o [ 44%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/__/Common/getTime.c.o [ 44%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf.dir/transportPerfConfig.c.o [ 44%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf.dir/transportThreads.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 44%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/__/Common/channelHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 44%] Building C object Cpp-C/Eta/Applications/Examples/VAProvider/CMakeFiles/VAProvider.dir/__/VACommon/tunnelStreamHandler.c.o [ 44%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/GenericMsgDecoder.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 44%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf.dir/__/Common/getTime.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 44%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf.dir/upacTransportPerf.c.o [ 44%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/rsslYieldCurveHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 45%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/__/Common/directoryProvider.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 45%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf.dir/__/Common/itemEncoder.c.o [ 45%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/GenericMsgEncoder.cpp.o [ 45%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/__/Common/itemEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 45%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/ProvPerf [ 45%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/__/VACommon/rsslVACacheHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 45%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/__/Common/latencyRandomArray.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf.dir/__/Common/channelHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/__/Common/getTime.c.o [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf.dir/__/Common/marketByOrderEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/__/VACommon/rsslVAMarketPriceItems.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf.dir/__/Common/latencyRandomArray.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/__/Common/marketPriceEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/__/VACommon/simpleTunnelMsgHandler.c.o [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf.dir/__/Common/getTime.c.o [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf.dir/__/Common/marketPriceEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/__/Common/marketByOrderEncoder.c.o [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/__/Common/statistics.c.o [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf.dir/__/Common/providerThreads.c.o [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/__/Common/itemEncoder.c.o [ 46%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/GetTime.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/HashTable.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/__/Common/latencyRandomArray.c.o [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf.dir/__/Common/statistics.c.o [ 46%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/__/VACommon/tunnelStreamHandler.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ItemCallbackClient.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/__/Common/xmlItemListParser.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/__/Common/marketByOrderEncoder.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf.dir/__/Common/xmlItemListParser.c.o [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/ConsPerf/CMakeFiles/ConsPerf.dir/__/Common/xmlMsgDataParser.c.o [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf.dir/__/Common/latencyRandomArray.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 46%] Building C object Cpp-C/Eta/Applications/Examples/VAConsumer/CMakeFiles/VAConsumer.dir/__/VACommon/rsslVASendMessage.c.o [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/__/Common/marketPriceEncoder.c.o [ 46%] Building C object Cpp-C/Eta/Applications/PerfTools/TransportPerf/CMakeFiles/TransportPerf.dir/__/Common/statistics.c.o [ 46%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ItemInfo.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 47%] Building C object Cpp-C/Eta/Applications/PerfTools/NIProvPerf/CMakeFiles/NIProvPerf.dir/__/Common/xmlMsgDataParser.c.o [ 47%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/__/Common/providerThreads.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 47%] Built target ProvPerf_shared [ 47%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Key.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 47%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Attrib.cpp.o [ 47%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/AckMsg.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 47%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/AckMsgDecoder.cpp.o [ 47%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/LoginHandler.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/LoginCallbackClient.cpp.o [ 48%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/__/Common/statistics.c.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 48%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/VANIProvider cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 48%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/__/Common/xmlItemListParser.c.o [ 48%] Building C object Cpp-C/Eta/Applications/PerfTools/ProvPerf/CMakeFiles/ProvPerf.dir/__/Common/xmlMsgDataParser.c.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Map.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/MapDecoder.cpp.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/AckMsgEncoder.cpp.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ActiveConfig.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/MapEncoder.cpp.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/MapEntry.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ChannelCallbackClient.cpp.o [ 48%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/VAProvider [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ClientSession.cpp.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/MarketItemHandler.cpp.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Msg.cpp.o [ 48%] Built target VANIProvider [ 48%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/WatchlistConsumer [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/MsgDecoder.cpp.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/MsgEncoder.cpp.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ComplexType.cpp.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Mutex.cpp.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Data.cpp.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/DataType.cpp.o [ 48%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/TransportPerf [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmAnsiPage.cpp.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/NoDataImpl.cpp.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmAnsiPageDecoder.cpp.o [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/DateTimeStringFormat.cpp.o [ 48%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/VAConsumer [ 48%] Built target WatchlistConsumer [ 48%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Decoder.cpp.o [ 49%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmAnsiPageEncoder.cpp.o [ 49%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/DictionaryHandler.cpp.o [ 49%] Built target VAProvider [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/DictionaryCallbackClient.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmArrayEntry.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmAsciiDecoder.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmArray.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmAscii.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmArrayDecoder.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmArrayEncoder.cpp.o [ 50%] Built target TransportPerf [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/DirectoryHandler.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/DirectoryCallbackClient.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmBaseImpl.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmBuffer.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/DirectoryServiceStore.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmBufferDecoder.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmCommonImpl.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ElementList.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ElementEntry.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ElementListDecoder.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmConsumer.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ElementListEncoder.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmConsumerActiveConfig.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmConsumerClient.cpp.o [ 50%] Built target VAConsumer [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ElementListSetDef.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/EmaBuffer.cpp.o [ 50%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmConsumerConfig.cpp.o [ 51%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmConsumerConfigImpl.cpp.o [ 51%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmConsumerErrorClient.cpp.o [ 51%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmConsumerEvent.cpp.o [ 51%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/EmaBufferInt.cpp.o [ 51%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmConsumerImpl.cpp.o [ 51%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/EmaBufferU16.cpp.o [ 51%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ConsPerf [ 51%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmDateDecoder.cpp.o [ 51%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmDate.cpp.o [ 51%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmDateTime.cpp.o [ 51%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/NIProvPerf [ 51%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/EmaBufferU16Int.cpp.o [ 51%] Linking C executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/ProvPerf [ 51%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/EmaPool.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/EmaConfigImpl.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmDateTimeDecoder.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmDouble.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/EmaStaticCombined.cpp.o [ 52%] Built target ConsPerf [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/EmaString.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/EmaStringInt.cpp.o [ 52%] Built target NIProvPerf [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmEnum.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmDoubleDecoder.cpp.o [ 52%] Built target ProvPerf [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Encoder.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmEnumDecoder.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/EncodeIterator.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/FieldList.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ErrorClientHandler.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ExceptionTranslator.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/FieldEntry.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmError.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/FieldListDecoder.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmErrorDecoder.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmException.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/FilterEntry.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/FieldListEncoder.cpp.o [ 52%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/FieldListSetDef.cpp.o [ 53%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmFloat.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/FilterList.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmFloatDecoder.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmInaccessibleLogFileException.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/FilterListDecoder.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmInaccessibleLogFileExceptionImpl.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/FilterListEncoder.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmInvalidConfigurationException.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmIntDecoder.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmInt.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/GenericMsg.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/GenericMsgDecoder.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmInvalidConfigurationExceptionImpl.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmInvalidHandleException.cpp.o [ 54%] Linking CXX static library ../../../build/lib/libgtest.a [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmInvalidHandleExceptionImpl.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmInvalidUsageException.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmInvalidUsageExceptionImpl.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/GenericMsgEncoder.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmIProviderActiveConfig.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/HashTable.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/GetTime.cpp.o [ 54%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ItemCallbackClient.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmIProviderConfigImpl.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmIProviderConfig.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmIProviderImpl.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ItemInfo.cpp.o [ 55%] Built target gtest [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmLoggerClient.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Key.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/LoginCallbackClient.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmMemoryExhaustionExceptionImpl.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmNiProviderConfig.cpp.o [ 55%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslDataTest/CMakeFiles/rsslDataTest.dir/rsslDataTest.C.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/LoginHandler.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmNiProviderActiveConfig.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmMemoryExhaustionException.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmNiProviderConfigImpl.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmNiProviderImpl.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Map.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/MapDecoder.cpp.o [ 55%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmNonRwfEncoder.cpp.o [ 55%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslMessageTest/CMakeFiles/rsslMessageTest.dir/rsslMessageTest.C.o [ 55%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/getTime.cpp.o [ 55%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/reactorUnitTests.cpp.o [ 55%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslMessageTest/CMakeFiles/rsslMessageTest_shared.dir/rsslMessageTest.C.o [ 56%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/TunnelStream/CMakeFiles/rsslTunnelStreamTest.dir/Consumer.C.o [ 56%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmOpaque.cpp.o [ 57%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/rdmDictionaryMsgTests.cpp.o [ 57%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/TunnelStream/CMakeFiles/rsslTunnelStreamTest.dir/CoreComponent.C.o [ 57%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmOpaqueDecoder.cpp.o [ 57%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslTransportUnitTest/CMakeFiles/rsslTransportUnitTest_shared.dir/rsslTransportUnitTest.cpp.o [ 58%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/MapEncoder.cpp.o [ 58%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/rdmDirectoryMsgTests.cpp.o [ 58%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/MapEntry.cpp.o [ 58%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslTransportUnitTest/CMakeFiles/rsslTransportUnitTest.dir/rsslTransportUnitTest.cpp.o [ 58%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/TunnelStream/CMakeFiles/rsslTunnelStreamTest.dir/Provider.C.o [ 58%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/TunnelStream/CMakeFiles/rsslTunnelStreamTest.dir/ReadEvent.C.o [ 58%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmOpaqueEncoder.cpp.o [ 58%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmOutOfRangeException.cpp.o [ 58%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/rdmLoginMsgTests.cpp.o [ 58%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/TunnelStream/CMakeFiles/rsslTunnelStreamTest.dir/TestReactor.C.o [ 58%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/rsslTestFramework.cpp.o [ 58%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/MarketItemHandler.cpp.o [ 58%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/TunnelStream/CMakeFiles/rsslTunnelStreamTest.dir/TestReactorComponent.C.o [ 58%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Msg.cpp.o [ 58%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/TunnelStream/CMakeFiles/rsslTunnelStreamTest.dir/TestReactorEvent.C.o [ 58%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmOutOfRangeExceptionImpl.cpp.o [ 58%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/rsslUnitTests.cpp.o [ 58%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/TunnelStream/CMakeFiles/rsslTunnelStreamTest.dir/TestUtil.C.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmProvider.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/MsgDecoder.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmProviderClient.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/MsgEncoder.cpp.o [ 59%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/rsslVATest.cpp.o [ 59%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/TunnelStream/CMakeFiles/rsslTunnelStreamTest.dir/TunnelStreamCoreProvider.C.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmProviderConfig.cpp.o [ 59%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/TunnelStream/CMakeFiles/rsslTunnelStreamTest.dir/TunnelStreamProvider.C.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmProviderErrorClient.cpp.o [ 59%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/rsslVATestUtil.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Mutex.cpp.o [ 59%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/TunnelStream/CMakeFiles/rsslTunnelStreamTest.dir/TunnelStreamTest.C.o [ 59%] Building C object Cpp-C/Eta/TestTools/UnitTests/TunnelStream/CMakeFiles/rsslTunnelStreamTest.dir/TunnelStreamGetTime.c.o [ 59%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/testFramework.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/NoDataImpl.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmProviderEvent.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmQos.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmProviderImpl.cpp.o [ 59%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/watchlistAggregationUnitTests.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmAnsiPage.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmAnsiPageDecoder.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmQosDecoder.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmReal.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 59%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/watchlistDirectoryUnitTests.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmAnsiPageEncoder.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmArray.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmRealDecoder.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmRmtes.cpp.o [ 59%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/watchlistMiscUnitTests.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmArrayEncoder.cpp.o [ 59%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmArrayDecoder.cpp.o [ 60%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmArrayEntry.cpp.o [ 60%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/watchlistRecoveryUnitTests.cpp.o [ 60%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmRmtesDecoder.cpp.o [ 60%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/watchlistSymbolListUnitTests.cpp.o [ 60%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmServerBaseImpl.cpp.o [ 60%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmAscii.cpp.o [ 60%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmAsciiDecoder.cpp.o [ 60%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmState.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmStateDecoder.cpp.o [ 61%] Building CXX object Cpp-C/Eta/TestTools/UnitTests/rsslVATest/CMakeFiles/rsslVATest.dir/watchlistTestFramework.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmSystemException.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmBaseImpl.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmSystemExceptionImpl.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmBuffer.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmTime.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmBufferDecoder.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmTimeDecoder.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmUInt.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmCommonImpl.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmUIntDecoder.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmConsumerActiveConfig.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmConsumer.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmUnsupportedDomainTypeException.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmConsumerClient.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmUnsupportedDomainTypeExceptionImpl.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmUtf8.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmUtf8Decoder.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmConsumerConfig.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmXml.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmXmlDecoder.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmConsumerConfigImpl.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/OmmXmlEncoder.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Payload.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmConsumerErrorClient.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmConsumerEvent.cpp.o [ 61%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmConsumerImpl.cpp.o [ 62%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Pipe.cpp.o [ 62%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/PostMsg.cpp.o [ 62%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/PostMsgDecoder.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmDate.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/PostMsgEncoder.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmDateDecoder.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ProgrammaticConfigure.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmDateTime.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/RefreshMsg.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmDateTimeDecoder.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/RefreshMsgDecoder.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmDouble.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/RefreshMsgEncoder.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ReqMsg.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ReqMsgDecoder.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmDoubleDecoder.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ReqMsgEncoder.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmEnum.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/RmtesBuffer.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/RmtesBufferImpl.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmEnumDecoder.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Series.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/SeriesDecoder.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmError.cpp.o [ 63%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmErrorDecoder.cpp.o [ 64%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/SeriesEncoder.cpp.o [ 64%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmException.cpp.o [ 64%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/SeriesEntry.cpp.o [ 64%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmFloat.cpp.o [ 64%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/ServerChannelHandler.cpp.o [ 64%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmFloatDecoder.cpp.o [ 64%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmInaccessibleLogFileException.cpp.o [ 64%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/StaticDecoder.cpp.o [ 64%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/StatusMsg.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmInaccessibleLogFileExceptionImpl.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmInt.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmIntDecoder.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/StatusMsgDecoder.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmInvalidConfigurationException.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/StatusMsgEncoder.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmInvalidConfigurationExceptionImpl.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmInvalidHandleException.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmInvalidUsageException.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmInvalidHandleExceptionImpl.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmInvalidUsageExceptionImpl.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/StreamId.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmIProviderActiveConfig.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmIProviderConfig.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/SummaryData.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmIProviderConfigImpl.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Thread.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmIProviderImpl.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmLoggerClient.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/TimeOut.cpp.o [ 65%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmMemoryExhaustionException.cpp.o [ 66%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmMemoryExhaustionExceptionImpl.cpp.o [ 66%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmNiProviderActiveConfig.cpp.o [ 66%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/TunnelStreamLoginReqMsgImpl.cpp.o [ 66%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmNiProviderConfig.cpp.o [ 66%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/TunnelStreamRequest.cpp.o [ 66%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmNiProviderConfigImpl.cpp.o [ 66%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/UpdateMsg.cpp.o [ 66%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmNiProviderImpl.cpp.o [ 66%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmNonRwfEncoder.cpp.o [ 66%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmOpaque.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/UpdateMsgDecoder.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/UpdateMsgEncoder.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Utilities.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/Vector.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmOpaqueDecoder.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmOpaqueEncoder.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmOutOfRangeException.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/VectorDecoder.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmOutOfRangeExceptionImpl.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/VectorEncoder.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmProvider.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmProviderClient.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/Impl/VectorEntry.cpp.o [ 67%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmProviderConfig.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmProviderErrorClient.cpp.o [ 68%] Building C object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/EmaVersion.c.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmProviderEvent.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Domain/Login/Impl/LoginRefresh.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Domain/Login/Impl/LoginRefreshImpl.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmProviderImpl.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmQos.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmQosDecoder.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Domain/Login/Impl/LoginReq.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmRealDecoder.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Domain/Login/Impl/LoginReqImpl.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmReal.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Domain/Login/Impl/LoginStatus.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Domain/Login/Impl/LoginStatusImpl.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Rdm/Impl/DataDictionary.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmRmtes.cpp.o [ 68%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmRmtesDecoder.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Rdm/Impl/DataDictionaryImpl.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmServerBaseImpl.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Rdm/Impl/DictionaryEntry.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmState.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Rdm/Impl/DictionaryEntryImpl.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Rdm/Impl/DictionaryUtility.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Rdm/Impl/EnumType.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmStateDecoder.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmSystemException.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Rdm/Impl/EnumTypeImpl.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Rdm/Impl/EnumTypeTable.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Rdm/Impl/EnumTypeTableImpl.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmSystemExceptionImpl.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmTime.cpp.o [ 69%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema_shared.dir/__/Rdm/Impl/RdmUtilities.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmTimeDecoder.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmUInt.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmUIntDecoder.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmUnsupportedDomainTypeException.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmUnsupportedDomainTypeExceptionImpl.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmUtf8Decoder.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmUtf8.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmXml.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmXmlDecoder.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/OmmXmlEncoder.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Payload.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Pipe.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/PostMsg.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/PostMsgDecoder.cpp.o [ 70%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/PostMsgEncoder.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ProgrammaticConfigure.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/RefreshMsg.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/RefreshMsgDecoder.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/RefreshMsgEncoder.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ReqMsg.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ReqMsgDecoder.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ReqMsgEncoder.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/RmtesBuffer.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/RmtesBufferImpl.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/SeriesDecoder.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Series.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/SeriesEncoder.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/SeriesEntry.cpp.o [ 71%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/ServerChannelHandler.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/StaticDecoder.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/StatusMsg.cpp.o [ 72%] Linking CXX shared library ../../../../../Cpp-C/Ema/Libs/CENTOS7_64_GCC482/Optimized/Shared/libema.so [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/StatusMsgDecoder.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/StatusMsgEncoder.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/StreamId.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/SummaryData.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Thread.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/TimeOut.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/TunnelStreamLoginReqMsgImpl.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/TunnelStreamRequest.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/UpdateMsg.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/UpdateMsgDecoder.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/UpdateMsgEncoder.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Utilities.cpp.o [ 72%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/Vector.cpp.o [ 73%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/VectorDecoder.cpp.o [ 73%] Linking CXX executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/rsslTransportUnitTest [ 73%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/VectorEncoder.cpp.o [ 73%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/Impl/VectorEntry.cpp.o [ 73%] Building C object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/EmaVersion.c.o [ 73%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Domain/Login/Impl/LoginRefresh.cpp.o [ 73%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Domain/Login/Impl/LoginRefreshImpl.cpp.o [ 73%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Domain/Login/Impl/LoginReq.cpp.o [ 73%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Domain/Login/Impl/LoginReqImpl.cpp.o [ 73%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Domain/Login/Impl/LoginStatus.cpp.o cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C [enabled by default] [ 73%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Domain/Login/Impl/LoginStatusImpl.cpp.o [ 73%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Rdm/Impl/DataDictionary.cpp.o [ 73%] Built target rsslTransportUnitTest_shared [ 73%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Rdm/Impl/DataDictionaryImpl.cpp.o [ 73%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Rdm/Impl/DictionaryEntry.cpp.o [ 73%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Rdm/Impl/DictionaryEntryImpl.cpp.o [ 74%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Rdm/Impl/DictionaryUtility.cpp.o [ 74%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Rdm/Impl/EnumType.cpp.o [ 74%] Built target libema_shared [ 74%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Rdm/Impl/EnumTypeImpl.cpp.o [ 74%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/100__MarketPrice__Streaming/CMakeFiles/Cons100_shared.dir/Consumer.cpp.o [ 74%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Rdm/Impl/EnumTypeTable.cpp.o [ 74%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/101__MarketPrice__QosPriority/CMakeFiles/Cons101_shared.dir/Consumer.cpp.o [ 74%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/102__MarketPrice__Snapshot/CMakeFiles/Cons102_shared.dir/Consumer.cpp.o [ 75%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/110__MarketPrice__FileConfig/CMakeFiles/Cons110_shared.dir/Consumer.cpp.o [ 75%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Rdm/Impl/EnumTypeTableImpl.cpp.o [ 75%] Building CXX object Cpp-C/Ema/Src/Access/CMakeFiles/libema.dir/__/Rdm/Impl/RdmUtilities.cpp.o [ 75%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/112__MarketPrice__TunnelingConnection/CMakeFiles/Cons112_shared.dir/Consumer.cpp.o [ 75%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/111__MarketPrice__UserSpecifiedFileConfig/CMakeFiles/Cons111_shared.dir/Consumer.cpp.o [ 75%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/130__MarketPrice__UserDisp/CMakeFiles/Cons130_shared.dir/Consumer.cpp.o [ 75%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/120__MarketPrice__FieldListWalk/CMakeFiles/Cons120_shared.dir/Consumer.cpp.o [ 75%] Linking CXX executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/rsslTransportUnitTest [ 75%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/260__MarketPrice__FieldListSearchByList/CMakeFiles/Cons260_shared.dir/Consumer.cpp.o [ 75%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/200__MarketPrice__Streaming/CMakeFiles/Cons200_shared.dir/Consumer.cpp.o [ 75%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/220__MarketByPrice__PrivateStream/CMakeFiles/Cons220_shared.dir/Consumer.cpp.o [ 75%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/140__MarketByOrder__Streaming/CMakeFiles/Cons140_shared.dir/Consumer.cpp.o [ 75%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/210__MarketByOrder__Streaming/CMakeFiles/Cons210_shared.dir/Consumer.cpp.o [ 75%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/121__MarketPrice__FieldListSearchByName/CMakeFiles/Cons121_shared.dir/Consumer.cpp.o [ 75%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/230__MarketByOrder__SwitchEntryAction/CMakeFiles/Cons230_shared.dir/Consumer.cpp.o [ 76%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/240__MarketPrice__RippleFields/CMakeFiles/Cons240_shared.dir/Consumer.cpp.o [ 76%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/270__SymbolList/CMakeFiles/Cons270_shared.dir/Consumer.cpp.o [ 76%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/291__Custom__DownCast/CMakeFiles/Cons291_shared.dir/Consumer.cpp.o [ 76%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/280__MarketPrice__Performance/CMakeFiles/Cons280_shared.dir/Consumer.cpp.o [ 76%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/250__Custom__Opaque/CMakeFiles/Cons250_shared.dir/Consumer.cpp.o [ 76%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/290__Custom__Decode/CMakeFiles/Cons290_shared.dir/Consumer.cpp.o [ 76%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/300__MarketPrice__Close/CMakeFiles/Cons300_shared.dir/Consumer.cpp.o [ 76%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons100 [ 76%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons101 [ 76%] Built target rsslTransportUnitTest [ 76%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/310__MarketPrice__Rmtes/CMakeFiles/Cons310_shared.dir/Consumer.cpp.o [ 76%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/301__MarketPrice__PriorityChange/CMakeFiles/Cons301_shared.dir/Consumer.cpp.o [ 76%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/320__Custom__GenericMsg/CMakeFiles/Cons320_shared.dir/Consumer.cpp.o [ 76%] Built target Cons101_shared [ 76%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons260 [ 76%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons110 [ 76%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons111 [ 77%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/330__Login__Streaming/CMakeFiles/Cons330_shared.dir/Consumer.cpp.o [ 77%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/331__Directory__Streaming/CMakeFiles/Cons331_shared.dir/Consumer.cpp.o [ 77%] Built target Cons100_shared [ 77%] Linking CXX executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/rsslTunnelStreamTest [ 77%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/332__Dictionary__Streaming/CMakeFiles/Cons332_shared.dir/Consumer.cpp.o [ 77%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons120 [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons200 [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons112 [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons280 [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons140 [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons102 [ 78%] Built target Cons260_shared [ 78%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/340__MarketPrice__OnStreamPost/CMakeFiles/Cons340_shared.dir/Consumer.cpp.o [ 78%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/333__Login__Streaming__DomainRep/CMakeFiles/Cons333_shared.dir/Consumer.cpp.o [ 78%] Built target Cons111_shared [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons121 [ 78%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/341__MarketPrice__OffStreamPost/CMakeFiles/Cons341_shared.dir/Consumer.cpp.o [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons250 [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons220 [ 78%] Built target Cons110_shared [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons270 [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons230 [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons130 [ 78%] Built target rsslTunnelStreamTest [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons240 [ 78%] Built target Cons112_shared [ 78%] Built target Cons140_shared [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons310 [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons301 [ 78%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons291 [ 79%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons300 [ 79%] Built target Cons121_shared [ 79%] Built target Cons120_shared [ 79%] Built target Cons200_shared [ 79%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/350__MarketPrice__PauseAll/CMakeFiles/Cons350_shared.dir/Consumer.cpp.o [ 79%] Built target Cons280_shared [ 79%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/360__MarketPrice__View/CMakeFiles/Cons360_shared.dir/Consumer.cpp.o [ 79%] Built target Cons250_shared [ 79%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons290 [ 79%] Built target Cons220_shared [ 79%] Built target Cons130_shared [ 79%] Built target Cons230_shared [ 79%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons210 [ 79%] Built target Cons102_shared [ 79%] Built target Cons300_shared [ 79%] Built target Cons240_shared [ 79%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/420__MarketPrice__AdminDomainConfig/CMakeFiles/Cons420_shared.dir/Consumer.cpp.o [ 79%] Built target Cons310_shared [ 79%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/370__MarketPrice__Batch/CMakeFiles/Cons370_shared.dir/Consumer.cpp.o [ 79%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/400__Custom__NestedMessaging/CMakeFiles/Cons400_shared.dir/Consumer.cpp.o [ 79%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/410__MarketPrice__HorizontalScaling/CMakeFiles/Cons410_shared.dir/Consumer.cpp.o [ 79%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/410__MarketPrice__HorizontalScaling/CMakeFiles/Cons410_shared.dir/ConsumerManager.cpp.o [ 79%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons320 [ 79%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/422__MarketPrice__ErrorClient/CMakeFiles/Cons422_shared.dir/Consumer.cpp.o [ 79%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/421__MarketPrice__ProgrammaticConfig/CMakeFiles/Cons421_shared.dir/Consumer.cpp.o [ 80%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/423__MarketPrice__AdminDomainConfig__DomainRep/CMakeFiles/Cons423_shared.dir/Consumer.cpp.o [ 80%] Built target Cons291_shared [ 80%] Built target Cons210_shared [ 80%] Built target Cons270_shared [ 80%] Built target Cons290_shared [ 80%] Built target Cons301_shared [ 80%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/430__MarketPrice__TrepAuthentication/CMakeFiles/Cons430_shared.dir/Consumer.cpp.o [ 80%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/440__System__TunnelStream/CMakeFiles/Cons440_shared.dir/Consumer.cpp.o [ 80%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons331 [ 80%] Built target Cons320_shared [ 80%] Linking CXX static library ../../../../../Cpp-C/Ema/Libs/CENTOS7_64_GCC482/Optimized/libema.a [ 80%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons340 [ 80%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons332 [ 80%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons333 [ 80%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons330 [ 80%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/100__MarketPrice__Streaming/CMakeFiles/IProv100_shared.dir/IProvider.cpp.o [ 80%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/102__MarketPrice__Snapshot/CMakeFiles/IProv102_shared.dir/IProvider.cpp.o [ 80%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons420 [ 80%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons350 [ 80%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons370 [ 80%] Built target Cons331_shared [ 80%] Built target Cons340_shared [ 80%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/161__Login__AcceptDeny__DomainRep/CMakeFiles/IProv161_shared.dir/IProvider.cpp.o [ 80%] Built target libema [ 80%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/200_Series/200__MarketPrice__Streaming/CMakeFiles/IProv200_shared.dir/IProvider.cpp.o [ 80%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/140__MarketByOrder__Streaming/CMakeFiles/IProv140_shared.dir/IProvider.cpp.o [ 80%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/150__MarketByOrder__Snapshot/CMakeFiles/IProv150_shared.dir/IProvider.cpp.o [ 80%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/160__Login__AcceptDeny/CMakeFiles/IProv160_shared.dir/IProvider.cpp.o [ 80%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/130__MarketPrice__UserDispatch/CMakeFiles/IProv130_shared.dir/IProvider.cpp.o [ 80%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons341 [ 81%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/200_Series/210__MarketByPrice__Streaming/CMakeFiles/IProv210_shared.dir/IProvider.cpp.o [ 81%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/200_Series/240__SourceDirectory__Fanout/CMakeFiles/IProv240_shared.dir/IProvider.cpp.o [ 81%] Built target Cons332_shared [ 81%] Built target Cons333_shared [ 81%] Built target Cons330_shared [ 81%] Built target Cons350_shared [ 81%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons440 [ 82%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons360 [ 82%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons423 [ 82%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/200_Series/250__GroupStatus__Fanout/CMakeFiles/IProv250_shared.dir/IProvider.cpp.o [ 82%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons430 [ 82%] Built target Cons420_shared [ 82%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/200_Series/260__Custom__NestedMsg/CMakeFiles/IProv260_shared.dir/IProvider.cpp.o [ 82%] Built target Cons370_shared [ 82%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/300__MarketPrice__Close/CMakeFiles/IProv300_shared.dir/IProvider.cpp.o [ 82%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/331__Directory__UserControl/CMakeFiles/IProv331_shared.dir/IProvider.cpp.o [ 83%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons410 [ 83%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/320__Custom__GenericMsg/CMakeFiles/IProv320_shared.dir/IProvider.cpp.o [ 83%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/332__Dictionary__UserControl/CMakeFiles/IProv332_shared.dir/IProvider.cpp.o [ 83%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/200_Series/280__MarketPrice__Performance/CMakeFiles/IProv280_shared.dir/IProvider.cpp.o [ 83%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/301__MarketPrice__PriorityChange/CMakeFiles/IProv301_shared.dir/IProvider.cpp.o [ 83%] Built target Cons440_shared [ 83%] Built target Cons341_shared [ 83%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons400 [ 83%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons421 [ 83%] Built target Cons423_shared [ 83%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/350__Dictionary__Streaming/CMakeFiles/IProv350_shared.dir/IProvider.cpp.o [ 83%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv102 [ 83%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv100 [ 83%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/350__Dictionary__Streaming/CMakeFiles/IProv350.dir/IProvider.cpp.o [ 83%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/Cons422 [ 83%] Built target Cons410_shared [ 83%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv140 [ 84%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/380__MarketPrice__ConnectionLost/CMakeFiles/IProv380_shared.dir/IProvider.cpp.o [ 84%] Built target Cons360_shared [ 84%] Built target Cons430_shared [ 84%] Built target Cons400_shared [ 84%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv150 [ 84%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv210 [ 84%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/380__MarketPrice__ConnectionLost/CMakeFiles/IProv380.dir/IProvider.cpp.o [ 84%] Built target IProv100_shared [ 84%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv200 [ 84%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv161 [ 84%] Built target Cons422_shared [ 84%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv160 [ 84%] Built target IProv102_shared [ 84%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/400_Series/421__MarketPrice__ProgrammaticConfig/CMakeFiles/IProv421_shared.dir/IProvider.cpp.o [ 84%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv331 [ 84%] Built target IProv140_shared [ 84%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv240 [ 84%] Built target Cons421_shared [ 84%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv130 [ 84%] Built target IProv210_shared [ 84%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv332 [ 84%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/400_Series/421__MarketPrice__ProgrammaticConfig/CMakeFiles/IProv421.dir/IProvider.cpp.o [ 84%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv300 [ 84%] Built target IProv161_shared [ 84%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv260 [ 84%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/100_Series/100__MarketPrice__Streaming/CMakeFiles/NIProv100_shared.dir/NiProvider.cpp.o [ 84%] Built target IProv200_shared [ 85%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv320 [ 85%] Built target IProv160_shared [ 85%] Built target IProv331_shared [ 85%] Built target IProv240_shared [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/100_Series/100__MarketPrice__Streaming/CMakeFiles/NIProv100.dir/NiProvider.cpp.o [ 85%] Built target IProv150_shared [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/100_Series/110__MarketByOrder__Streaming/CMakeFiles/NIProv110.dir/NiProvider.cpp.o [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/200_Series/200__MarketPrice__Streaming/CMakeFiles/NIProv200_shared.dir/NiProvider.cpp.o [ 85%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv250 [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/200_Series/200__MarketPrice__Streaming/CMakeFiles/NIProv200.dir/NiProvider.cpp.o [ 85%] Built target IProv130_shared [ 85%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv280 [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/200_Series/210__MarketByOrder__Streaming/CMakeFiles/NIProv210_shared.dir/NiProvider.cpp.o [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/100_Series/110__MarketByOrder__Streaming/CMakeFiles/NIProv110_shared.dir/NiProvider.cpp.o [ 85%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv350 [ 85%] Built target IProv260_shared [ 85%] Built target IProv250_shared [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/200_Series/210__MarketByOrder__Streaming/CMakeFiles/NIProv210.dir/NiProvider.cpp.o [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/200_Series/250__MarketPrice__Performance/CMakeFiles/NIProv250_shared.dir/NiProvider.cpp.o [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/200_Series/250__MarketPrice__Performance/CMakeFiles/NIProv250.dir/NiProvider.cpp.o [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/300_Series/300__MarketPrice__Streaming/CMakeFiles/NIProv300_shared.dir/NiProvider.cpp.o [ 85%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv380 [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/200_Series/251__MarketPrice__Performance__KeyByServiceId/CMakeFiles/NIProv251_shared.dir/NiProvider.cpp.o [ 85%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv380 [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/200_Series/251__MarketPrice__Performance__KeyByServiceId/CMakeFiles/NIProv251.dir/NiProvider.cpp.o [ 85%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv350 [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/300_Series/300__MarketPrice__Streaming/CMakeFiles/NIProv300.dir/NiProvider.cpp.o [ 85%] Built target IProv300_shared [ 85%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv301 [ 85%] Built target IProv350_shared [ 85%] Built target IProv320_shared [ 85%] Built target IProv332_shared [ 85%] Built target IProv280_shared [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/300_Series/310__MarketByOrder__Streaming/CMakeFiles/NIProv310_shared.dir/NiProvider.cpp.o [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/300_Series/310__MarketByOrder__Streaming/CMakeFiles/NIProv310.dir/NiProvider.cpp.o [ 85%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv100 [ 85%] Built target IProv380_shared [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/300_Series/320__MarketPrice__Streaming__StatusClosed/CMakeFiles/NIProv320_shared.dir/NiProvider.cpp.o [ 85%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv210 [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/300_Series/350__Dictionary__Streaming/CMakeFiles/NIProv350.dir/NiProvider.cpp.o [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/300_Series/320__MarketPrice__Streaming__StatusClosed/CMakeFiles/NIProv320.dir/NiProvider.cpp.o [ 85%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv100 [ 85%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/300_Series/350__Dictionary__Streaming/CMakeFiles/NIProv350_shared.dir/NiProvider.cpp.o [ 86%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/300_Series/340__Login__Streaming/CMakeFiles/NIProv340_shared.dir/NiProvider.cpp.o [ 86%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv200 [ 86%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/300_Series/340__Login__Streaming/CMakeFiles/NIProv340.dir/NiProvider.cpp.o [ 86%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/300_Series/360__MarketPrice__ConnectionRecovery/CMakeFiles/NIProv360_shared.dir/NiProvider.cpp.o [ 86%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv110 [ 86%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/IProv421 [ 86%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/300_Series/360__MarketPrice__ConnectionRecovery/CMakeFiles/NIProv360.dir/NiProvider.cpp.o [ 86%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv110 [ 86%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/400_Series/421__MarketPrice__ProgrammaticConfig/CMakeFiles/NIProv421_shared.dir/NiProvider.cpp.o [ 86%] Built target IProv301_shared [ 87%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv200 [ 87%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/400_Series/421__MarketPrice__ProgrammaticConfig/CMakeFiles/NIProv421.dir/NiProvider.cpp.o [ 87%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/400_Series/430__MarketPrice__TrepAuthentication/CMakeFiles/NIProv430_shared.dir/NiProvider.cpp.o [ 87%] Built target IProv380 [ 87%] Built target NIProv100_shared [ 87%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv251 [ 88%] Building CXX object Cpp-C/Ema/Examples/Training/NiProvider/400_Series/430__MarketPrice__TrepAuthentication/CMakeFiles/NIProv430.dir/NiProvider.cpp.o [ 88%] Built target IProv350 [ 88%] Built target IProv421_shared [ 88%] Built target NIProv210_shared [ 88%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv300 [ 88%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv421 [ 88%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv250 [ 88%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv210 [ 88%] Built target NIProv200_shared [ 89%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv251 [ 89%] Built target NIProv110_shared [ 89%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv310 [ 89%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf_shared.dir/EmaCppConsPerf.cpp.o [ 89%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf_shared.dir/ConsPerfConfig.cpp.o [ 89%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf.dir/EmaCppConsPerf.cpp.o [ 89%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv250 [ 89%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf_shared.dir/ConsumerThread.cpp.o [ 89%] Built target NIProv110 [ 89%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf.dir/ConsPerfConfig.cpp.o [ 89%] Built target NIProv300_shared [ 89%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/AckMsgTests.cpp.o [ 89%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf.dir/ConsumerThread.cpp.o [ 89%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv350 [ 89%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv340 [ 89%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf_shared.dir/__/Common/AppUtil.cpp.o [ 89%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv310 [ 89%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv320 [ 89%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/100__MarketPrice__Streaming/CMakeFiles/Cons100.dir/Consumer.cpp.o [ 89%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf_shared.dir/__/Common/CtrlBreakHandler.cpp.o [ 89%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv300 [ 90%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf.dir/__/Common/CtrlBreakHandler.cpp.o [ 90%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf.dir/__/Common/AppUtil.cpp.o [ 90%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/ArrayTests.cpp.o [ 90%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/DataDictionaryTest.cpp.o [ 90%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf_shared.dir/__/Common/GetTime.cpp.o [ 90%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf.dir/__/Common/GetTime.cpp.o [ 90%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv320 [ 90%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/101__MarketPrice__QosPriority/CMakeFiles/Cons101.dir/Consumer.cpp.o [ 90%] Built target NIProv100 [ 90%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv360 [ 90%] Built target NIProv250_shared [ 90%] Built target NIProv251 [ 90%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf_shared.dir/__/Common/Mutex.cpp.o [ 90%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/DataUnitTest.cpp.o [ 90%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/DateTimeTests.cpp.o [ 90%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf.dir/__/Common/Mutex.cpp.o [ 90%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/DomainTypeTest.cpp.o [ 91%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf_shared.dir/__/Common/PerfConfig.cpp.o [ 91%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv360 [ 91%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf.dir/__/Common/PerfConfig.cpp.o [ 91%] Built target NIProv310_shared [ 91%] Built target NIProv251_shared [ 91%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/102__MarketPrice__Snapshot/CMakeFiles/Cons102.dir/Consumer.cpp.o [ 91%] Built target NIProv350_shared [ 91%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv430 [ 91%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf.dir/__/Common/Statistics.cpp.o [ 91%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/110__MarketPrice__FileConfig/CMakeFiles/Cons110.dir/Consumer.cpp.o [ 91%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf.dir/__/Common/ThreadAffinity.cpp.o [ 91%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv350 [ 91%] Built target NIProv340_shared [ 91%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf_shared.dir/__/Common/Statistics.cpp.o [ 91%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf.dir/__/Common/XmlItemParser.cpp.o [ 91%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/ElementListTests.cpp.o [ 91%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf_shared.dir/__/Common/ThreadAffinity.cpp.o [ 91%] Built target NIProv200 [ 91%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv340 [ 91%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv430 [ 91%] Built target IProv421 [ 91%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/EmaAppClient.cpp.o [ 91%] Built target NIProv320_shared [ 91%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/NIProv421 [ 91%] Built target NIProv310 [ 91%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/EmaBufferTest.cpp.o [ 91%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/NIProv421 [ 91%] Building CXX object Cpp-C/Ema/Examples/PerfTools/EmaCppConsPerf/CMakeFiles/EmaCppConsPerf_shared.dir/__/Common/XmlItemParser.cpp.o [ 91%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/111__MarketPrice__UserSpecifiedFileConfig/CMakeFiles/Cons111.dir/Consumer.cpp.o [ 91%] Built target NIProv360_shared [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/EmaConfigTest.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/EmaStringTests.cpp.o [ 92%] Built target NIProv430_shared [ 92%] Built target NIProv210 [ 92%] Built target NIProv250 [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/EmaVectorTest.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/FieldListTests.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/112__MarketPrice__TunnelingConnection/CMakeFiles/Cons112.dir/Consumer.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/FilterListTests.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/GenericMsgTests.cpp.o [ 92%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons101 [ 92%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/120__MarketPrice__FieldListWalk/CMakeFiles/Cons120.dir/Consumer.cpp.o [ 92%] Built target NIProv300 [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/LoginHelperTest.cpp.o [ 92%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons100 [ 92%] Built target NIProv360 [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/MapTests.cpp.o [ 92%] Built target NIProv421_shared [ 92%] Built target NIProv320 [ 92%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/121__MarketPrice__FieldListSearchByName/CMakeFiles/Cons121.dir/Consumer.cpp.o [ 92%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons102 [ 92%] Built target NIProv350 [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/OmmExceptionTests.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/NoDataSizeTest.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/PostMsgTests.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/130__MarketPrice__UserDisp/CMakeFiles/Cons130.dir/Consumer.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/200__MarketPrice__Streaming/CMakeFiles/Cons200.dir/Consumer.cpp.o [ 92%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons110 [ 92%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/100_Series/140__MarketByOrder__Streaming/CMakeFiles/Cons140.dir/Consumer.cpp.o [ 92%] Built target NIProv430 [ 92%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/210__MarketByOrder__Streaming/CMakeFiles/Cons210.dir/Consumer.cpp.o [ 92%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons111 [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/RequestMsgTests.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/RefreshMsgTests.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/SeriesTests.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/RmtesBufferTest.cpp.o [ 92%] Built target NIProv340 [ 92%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/220__MarketByPrice__PrivateStream/CMakeFiles/Cons220.dir/Consumer.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/230__MarketByOrder__SwitchEntryAction/CMakeFiles/Cons230.dir/Consumer.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/240__MarketPrice__RippleFields/CMakeFiles/Cons240.dir/Consumer.cpp.o [ 92%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/250__Custom__Opaque/CMakeFiles/Cons250.dir/Consumer.cpp.o [ 93%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/StatusMsgTests.cpp.o [ 93%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/TestUtilities.cpp.o [ 93%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/TunnelStreamRequestTests.cpp.o [ 93%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/260__MarketPrice__FieldListSearchByList/CMakeFiles/Cons260.dir/Consumer.cpp.o [ 93%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/270__SymbolList/CMakeFiles/Cons270.dir/Consumer.cpp.o [ 93%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/UpdateMsgTests.cpp.o [ 94%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/280__MarketPrice__Performance/CMakeFiles/Cons280.dir/Consumer.cpp.o [ 94%] Built target Cons101 [ 94%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/290__Custom__Decode/CMakeFiles/Cons290.dir/Consumer.cpp.o [ 94%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons112 [ 94%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/200_Series/291__Custom__DownCast/CMakeFiles/Cons291.dir/Consumer.cpp.o [ 94%] Building CXX object Cpp-C/Ema/Examples/Test/UnitTest/CMakeFiles/EmaUnitTest.dir/VectorTests.cpp.o [ 94%] Built target NIProv421 [ 94%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/301__MarketPrice__PriorityChange/CMakeFiles/Cons301.dir/Consumer.cpp.o [ 94%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/310__MarketPrice__Rmtes/CMakeFiles/Cons310.dir/Consumer.cpp.o [ 94%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/320__Custom__GenericMsg/CMakeFiles/Cons320.dir/Consumer.cpp.o [ 94%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/330__Login__Streaming/CMakeFiles/Cons330.dir/Consumer.cpp.o [ 94%] Linking CXX executable ../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Shared/EmaCppConsPerf [ 94%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons130 [ 94%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/300__MarketPrice__Close/CMakeFiles/Cons300.dir/Consumer.cpp.o [ 94%] Linking CXX executable ../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/EmaCppConsPerf [ 94%] Built target Cons111 [ 94%] Built target Cons100 [ 94%] Built target Cons102 [ 94%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons120 [ 94%] Built target Cons110 [ 94%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/331__Directory__Streaming/CMakeFiles/Cons331.dir/Consumer.cpp.o [ 94%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/332__Dictionary__Streaming/CMakeFiles/Cons332.dir/Consumer.cpp.o [ 94%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/333__Login__Streaming__DomainRep/CMakeFiles/Cons333.dir/Consumer.cpp.o [ 94%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons230 [ 94%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/360__MarketPrice__View/CMakeFiles/Cons360.dir/Consumer.cpp.o [ 94%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/350__MarketPrice__PauseAll/CMakeFiles/Cons350.dir/Consumer.cpp.o [ 95%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/340__MarketPrice__OnStreamPost/CMakeFiles/Cons340.dir/Consumer.cpp.o [ 95%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons200 [ 95%] Built target EmaCppConsPerf_shared [ 95%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons210 [ 95%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/341__MarketPrice__OffStreamPost/CMakeFiles/Cons341.dir/Consumer.cpp.o [ 95%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons140 [ 95%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons280 [ 95%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/300_Series/370__MarketPrice__Batch/CMakeFiles/Cons370.dir/Consumer.cpp.o [ 95%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons270 [ 95%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons220 [ 95%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/400__Custom__NestedMessaging/CMakeFiles/Cons400.dir/Consumer.cpp.o [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons121 [ 96%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/410__MarketPrice__HorizontalScaling/CMakeFiles/Cons410.dir/Consumer.cpp.o [ 96%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/410__MarketPrice__HorizontalScaling/CMakeFiles/Cons410.dir/ConsumerManager.cpp.o [ 96%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/420__MarketPrice__AdminDomainConfig/CMakeFiles/Cons420.dir/Consumer.cpp.o [ 96%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/421__MarketPrice__ProgrammaticConfig/CMakeFiles/Cons421.dir/Consumer.cpp.o [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons250 [ 96%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/422__MarketPrice__ErrorClient/CMakeFiles/Cons422.dir/Consumer.cpp.o [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons240 [ 96%] Built target Cons130 [ 96%] Built target Cons112 [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons260 [ 96%] Built target Cons120 [ 96%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/423__MarketPrice__AdminDomainConfig__DomainRep/CMakeFiles/Cons423.dir/Consumer.cpp.o [ 96%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/430__MarketPrice__TrepAuthentication/CMakeFiles/Cons430.dir/Consumer.cpp.o [ 96%] Building CXX object Cpp-C/Ema/Examples/Training/Consumer/400_Series/440__System__TunnelStream/CMakeFiles/Cons440.dir/Consumer.cpp.o [ 96%] Built target Cons200 [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons300 [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons310 [ 96%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/100__MarketPrice__Streaming/CMakeFiles/IProv100.dir/IProvider.cpp.o [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons330 [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons290 [ 96%] Built target EmaCppConsPerf [ 96%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/102__MarketPrice__Snapshot/CMakeFiles/IProv102.dir/IProvider.cpp.o [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons333 [ 96%] Built target Cons140 [ 96%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/130__MarketPrice__UserDispatch/CMakeFiles/IProv130.dir/IProvider.cpp.o [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons301 [ 96%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/140__MarketByOrder__Streaming/CMakeFiles/IProv140.dir/IProvider.cpp.o [ 96%] Built target Cons230 [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons291 [ 96%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/150__MarketByOrder__Snapshot/CMakeFiles/IProv150.dir/IProvider.cpp.o [ 96%] Built target Cons270 [ 96%] Built target Cons240 [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons360 [ 96%] Built target Cons210 [ 96%] Built target Cons280 [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons370 [ 96%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons331 [ 97%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/160__Login__AcceptDeny/CMakeFiles/IProv160.dir/IProvider.cpp.o [ 97%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons340 [ 97%] Built target Cons121 [ 97%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons332 [ 97%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons400 [ 97%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons320 [ 97%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons410 [ 97%] Built target Cons220 [ 97%] Built target Cons260 [ 97%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons420 [ 97%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons350 [ 97%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/100_Series/161__Login__AcceptDeny__DomainRep/CMakeFiles/IProv161.dir/IProvider.cpp.o [ 97%] Built target Cons250 [ 97%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/200_Series/210__MarketByPrice__Streaming/CMakeFiles/IProv210.dir/IProvider.cpp.o [ 97%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/200_Series/200__MarketPrice__Streaming/CMakeFiles/IProv200.dir/IProvider.cpp.o [ 97%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons421 [ 97%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/200_Series/240__SourceDirectory__Fanout/CMakeFiles/IProv240.dir/IProvider.cpp.o [ 97%] Built target Cons330 [ 97%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons423 [ 97%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/200_Series/250__GroupStatus__Fanout/CMakeFiles/IProv250.dir/IProvider.cpp.o [ 97%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/200_Series/260__Custom__NestedMsg/CMakeFiles/IProv260.dir/IProvider.cpp.o [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv102 [ 98%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/200_Series/280__MarketPrice__Performance/CMakeFiles/IProv280.dir/IProvider.cpp.o [ 98%] Built target Cons290 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv130 [ 98%] Built target Cons333 [ 98%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/300__MarketPrice__Close/CMakeFiles/IProv300.dir/IProvider.cpp.o [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons422 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv160 [ 98%] Built target Cons301 [ 98%] Built target Cons291 [ 98%] Built target Cons300 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons341 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv150 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons430 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/Cons440 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv140 [ 98%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/301__MarketPrice__PriorityChange/CMakeFiles/IProv301.dir/IProvider.cpp.o [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv100 [ 98%] Built target Cons310 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv161 [ 98%] Built target Cons332 [ 98%] Built target Cons360 [ 98%] Built target Cons340 [ 98%] Built target Cons320 [ 98%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/320__Custom__GenericMsg/CMakeFiles/IProv320.dir/IProvider.cpp.o [ 98%] Built target Cons331 [ 98%] Built target Cons350 [ 98%] Built target Cons370 [ 98%] Built target Cons400 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv260 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv200 [ 98%] Built target Cons410 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv210 [ 98%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/331__Directory__UserControl/CMakeFiles/IProv331.dir/IProvider.cpp.o [ 98%] Built target Cons421 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv240 [ 98%] Built target Cons423 [ 98%] Built target Cons420 [ 98%] Built target IProv130 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv250 [ 98%] Built target IProv102 [ 98%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv300 [ 98%] Building CXX object Cpp-C/Ema/Examples/Training/IProvider/300_Series/332__Dictionary__UserControl/CMakeFiles/IProv332.dir/IProvider.cpp.o [ 98%] Built target Cons422 [ 99%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv280 [ 99%] Built target IProv160 [ 99%] Built target Cons430 [ 99%] Built target IProv150 [ 99%] Built target Cons440 [ 99%] Built target IProv210 [ 99%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv331 [ 99%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv320 [ 99%] Built target Cons341 [ 99%] Built target IProv100 [ 99%] Built target IProv260 [ 99%] Built target IProv300 [ 99%] Built target IProv161 [ 99%] Built target IProv140 [ 99%] Built target IProv200 [ 99%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv301 [ 99%] Built target IProv250 [ 99%] Linking CXX executable ../../../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/IProv332 [ 99%] Built target IProv320 [ 99%] Built target IProv240 [ 99%] Built target IProv280 [ 99%] Built target IProv331 [ 99%] Built target IProv301 [ 99%] Built target IProv332 [ 99%] Linking CXX executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/rsslDataTest [ 99%] Built target rsslDataTest [ 99%] Linking CXX executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/rsslMessageTest [ 99%] Built target rsslMessageTest [ 99%] Linking CXX executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/Shared/rsslMessageTest [ 99%] Built target rsslMessageTest_shared [100%] Linking CXX executable ../../../../../../Cpp-C/Eta/Executables/CENTOS7_64_GCC482/Optimized/rsslVATest [100%] Built target rsslVATest [100%] Linking CXX executable ../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482/Optimized/EmaUnitTest [100%] Built target EmaUnitTest
elektronrefinitiv-realtimeelektron-sdk
@zfm666888
From the compile log, the compiler process is 100% completed. The executable files are created in this ../../../../../../Cpp-C/Ema/Executables/CENTOS7_64_GCC482 directory.
There are a lot of warnings regarding ‘-std=c++11’. Have you modified the cmake script?
Please clarify the problem.
